How Can Binary Vectors Be Ordered Through Transformation?
  • Thread starter Thread starter baxy
    Binary Vector
baxy
Hi,
This is my first post and I must worn you that I'm not a mathematician. I am just a regular blonk looking for help concerning the following problem.
What i have is a set (T) of binary vectors:A: 100110
B: 000110
C: 010110now what i am trying to figure out is there a transformation, a function to transform given vectors in such a way that
A>B>C
where a relation > on T is given by the fact that to convert
B->A takes 1 step
C->A takes 2 steps
C->B takes 1 step
Can anyone suggest a book or a paper where such things are discussed , or give a few pointers?
Thank you,
baxy
PS
and the relation can ba symmetrical
A<B<C
as long as the order is preserved
Hey baxy and welcome to the forums.
I'm not exactly sure what you are trying to do, but it seems that you're given a set T = {T1,T2,T3} and you want to find a transformation that takes T1,T2,T3 in which f(T1) > f(T2) > f(T3) or f(T1) < f(T2) < f(T3).
One easy transformation that comes to mind if we assume that all entries of the set are non-zero is to use a transformation that maps an input vector to an output vector. In other words, using your set with three elements define F to be:
F(T1,T2,T3) = [T1+T2+T3,T2+T3,T3] where the output is a vector with three elements.
Since this is a linear transformation, you can create an appropriate matrix that represents this transformation and define that as your operator.
Is this what you had in mind?
Also I didn't take into account the binary nature of your number, so you would have to compensate for this in your computation.
ok, but i didn't quite understand how can i from this output vector figure out that T1>T2>T3 ? so what i need t do is transform my vectors into something and then just by sorting the transforms, figure out that T1_{A} needs 1 transformation step to be converted to T2_{B} and 2 transformation step to be converted to T3_{C}.
This is my problem.
This is my problem.
Ohh I see what you mean.
Well to sort two elements the first one is min(T1,T2) and the last is max(T1,T2). Can you adapt this for three elements?
Thread 'Determine whether ##125## is a unit in ##\mathbb{Z_471}##'
This is the question, I understand the concept, in ##\mathbb{Z_n}## an element is a is a unit if and only if gcd( a,n) =1. My understanding of backwards substitution, ... i have using Euclidean algorithm, ##471 = 3⋅121 + 108## ##121 = 1⋅108 + 13## ##108 =8⋅13+4## ##13=3⋅4+1## ##4=4⋅1+0## using back-substitution, ##1=13-3⋅4## ##=(121-1⋅108)-3(108-8⋅13)## ... ##= 121-(471-3⋅121)-3⋅471+9⋅121+24⋅121-24(471-3⋅121## ##=121-471+3⋅121-3⋅471+9⋅121+24⋅121-24⋅471+72⋅121##...
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
