How can I calculate the angle of an airplane's wings during a circular motion?
To calculate the angle of an airplane's wings during circular motion, the relationship tan(Q) = (v^2)/(gr) is derived from the balance of forces acting on the plane. In level flight, the lift force must counteract the weight of the airplane, but when banking occurs, the lift force's vertical component must still equal the weight while its horizontal component provides the necessary centripetal force. The equation L' sin(Q) = M(v^2)/r is established, where L' is the adjusted lift force when the wings are banked. The discussion clarifies that the lift force can be expressed as L' = mg/cos(Q), leading to the conclusion that mass m cancels out when deriving the final relationship. Understanding these force dynamics is crucial for accurately calculating the wing angle during turns.
Thiendrah
A pilot with mass m fles an airplane at a speed of v in a turn of radius r. Prove that angle of the wings of the airplane to the horizontal is tanQ=(VxV)/gr
This was asked on my first exam last week.
Since it's tangent. All we need to get is the force, result will equal to (FxcosQ)/(FxSinQ)=(VxV)/gr?
I'm not getting anywhere with this? Can someone help me?
The issue we are concerned with here is how we get the plane to move along a circle of radius r. Start with thinking about the plane flying with the wings level (in a horizontal plane). There are two forces acting on the plane in the vertical direction: its weight, Mg, and the "lift", L, supplied by the wings. With the plane in level flight, these vertical forces must balance.
Now we want the plane to make a turn, so we "bank" the wings by an angle Q. So the "lifting force" will be off-vertical by an angle Q; since it must still balance the weight of the plane vertically, its magnitude will change to L' . (How is it related to Mg?)
This altered lifting force now has a horizontal component as well. This component of L', which will equal L' sin Q , is what supplies the centripetal force to pull the plane into a circular path (for the interval of the wing-banking). So we have
L' sin Q = M·(v^2)/r .
Try things from there.
BTW, a similar argument can be used to explain why a cyclist (leg- or motor-powered) must "lean into the turn" when they want to go round a corner...
oh, I think i got it.
So we got our force FnXsinQ=m.a=m.(vXv)/r, also the other component is "mg", so
when you divide those two, you will get mvv/gr.
thanks a lot.
I'm presuming that what you are calling 'Fn' corresponds to the lift force; there is no normal force for an aviation problem. The lift force when the plane is banked by an angle Q will be L' = mg/cos Q .
In your last sentence, shouldn't the mass m have divided out?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
