Fortran How can I change the starting index of an array in Fortran?
  • Thread starter Thread starter Giammy85
    Fault Fortran90
The discussion revolves around a Fortran program that encounters a segmentation fault due to improper array indexing. The user attempts to read files from subdirectories and create output files, but the issue arises when the program tries to access the first element of an array with a zero index. In Fortran, arrays are 1-based by default, and attempting to assign a value to `fileout(0)` leads to unexpected behavior. The solution involves either adjusting the array declaration to allow for a zero index or adhering to the 1-based indexing convention by starting the loop from 1. The conversation emphasizes the importance of understanding array indexing in Fortran to avoid such errors.
Giammy85
I'm try to read some files in subdirectories and create some other files in my present location:
program multiread
implicit none
!variables
integer :: n, k, i
integer :: j, m2
real(8) :: pratio, crap, rmsttv
character(len=42) :: filein(98)
character(len=10) :: fileout(14)
character (LEN=26) :: path
character(len=2) number, mass
j = 1
do i=0, 6
m2=5*i
if (m2==0) then
m2=1
end if
write(mass,998) m2
998 format(i2.2)
write(*,*) j
fileout(i)=mass//'_000.dat'
write(*,*) fileout(i),j
open(unit=i+10,file=fileout(i),status='replace',access="append")
! write(*,*) j
do n=0,6
pratio=1.5+0.25*n
! write(*,*) pratio
write(number,998) j
! write(*,*) j
! 999 format(i2.2)
write(*,*) number
path='/scratch/project3/set1/'//number//'/'
filein(j)=path//'periodrmsttv.dat'
write(*,*) filein(j)
open(unit=j+40,file=filein(j),status='old')
read (j+40,*) crap
read (j+40, '(f14.6)') rmsttv
write (i+10,'(f4.2,f14.6)') pratio, rmsttv
close (j+40)
j=j+2
end do
close (i+10)
end do
end program multiread
I receive a segmentation fault message: debugging I have found the value of j change from 1 to a random number just after having defined fileout(i)=mass//'_000.dat'
How to solve this problem?
Thanks
Technology news on Phys.org
When you post a code sample, put [ code ] and [ /code ] tags around it (omit the spaces I showed). This preserves your indentation and makes your code easier to read. I have done that below.
Code:
program multiread
implicit none
!variables
integer :: n, k, i
integer :: j, m2
j = 1
do i=0, 6
m2=5*i
if (m2==0) then
m2=1
end if
	   write(mass,998) m2
	998  format(i2.2)
      write(*,*) j
 !     write(*,*) j
	do n=0,6
	pratio=1.5+0.25*n
!      write(*,*) pratio
	      write(number,998) j
!      write(*,*) j
!	 999  format(i2.2)
      write(*,*) number
		read (j+40,*) crap
		close (j+40)
	j=j+2
	end do
close (i+10)
end do
Thanks
I believe this is your problem:
Code:
do i=0, 6
  m2=5*i
  if (m2==0) then
  m2=1
  end if
  write(mass,998) m2
  998 format(i2.2)
  write(*,*) j
end do
Arrays in Fortran are 1-based, by default[/color], which means that the smallest index is 1. In your code, i starts out at 0, and you attempt to store the value of mass in fileout(0).
Mark44 said:
Arrays in Fortran are 1-based, which means that the smallest index is 1. In your code, i starts out at 0, and you attempt to store the value of mass in fileout(0).
You can declare a Fortran array with any integer bounds if you want, for eaxmple
Code:
character(len=10) :: fileout(0:14)
makes the smallest index 0 not 1.
But if you are going to use Fortran a lot, you need to get used to working with arrays that start from index 1.
Thanks, solved!
Code:
I thought there would be a way to do it. What I meant to say was that by default, an array is 1-based.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
