How can I securely fix a bearing inside a pipe without permanent installation?
  • Thread starter Thread starter hamdan_neo
    Bearing Pipe
To securely fix a bearing inside a pipe without permanent installation, one effective method involves drilling a hole through the pipe wall to access the outer race of a sealed roller bearing. A small socket head set screw can then be used to apply pressure on the outer race, securing it in place. For added stability, a jam-nut can be employed on the set screw to prevent movement. In cases of significant vibration, dimpling the outer race at the contact point can enhance security. This approach is recognized as a practical solution in machining and welding applications.
hamdan_neo
hello,
i want to fix a bearing inside a pipe but not "permanently" so i can remove it and change it whenever i need.
please if anyone has a method for fixing it, share it with me ?
If the wall is thick enough you could drill at least one hole through the wall of the pipe to intersect the location of the outer race, assuming this is a sealed roller bearing. You could then tap the hole with an appropriate thread for a small socket head set screw. Position the bearing where it will normally reside within the pipe and tighten the set screw to apply pressure to the outer race and secure it in place. I you were to use a longer than required set screw you could screw a nut down on the protruding segment of thread and tighten it after the bearing was secured to act as a Jam-nut which would aid in restricting the movement of the set screw.
I work in a Machining/Welding business and have used this as a ''Quick n' Dirty'' method for fastening an object temporarily inside a housing or enclosure.
Excellent suggestion, Molitor. If there is any significant vibration or stress upon the bearing, though, I would further recommend dimpling the outer race where the set screw contacts it, to secure it a bit better (like how a hand-held die is fixed in its handle).
If you want needless elegance, or to show off, you could thread the outside of the race and the inside of the pipe and screw them together. :biggrin:
Thanks a lot molitor, it is an excellent idea, i will work on it now ... really thanks again :D
I'm really glad I could help. I know thousands of tricks when it comes to applications. Its what I do for a living.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
