B How did we measure the mass of Quarks?
mpolo
I have searched the Internet and I have not found a simple layman's explanation other than this.
We observe their decay products of quarks and that is what the mass is reconstructed from. Is this correct? If so I would like to have that confirmed. I am just looking for a simple direct explanation of the process used. If there is a simple formula that goes with this process I would like to see that as well.
mpolo said:
Is this correct?
Sort of. "Decay products of quarks" is not really a correct description of what is observed in the high energy experiments that provide the data used to estimate quark masses. It would be more accurate to say that we shoot things at hadrons (strongly interacting particles that contain quarks, like protons or hyperons) and measure what comes out; sometimes what comes out is just what we shot in with its energy and momentum changed (as in the deep inelastic scattering experiments in the 1960s--electrons were shot at nucleons and behaved as though they were bouncing off point-like particles inside the nucleons, which ended up being identified as the up and down quarks), sometimes it's a more complicated mess of other particles which indicate the presence of quarks inside the hadrons (as in the experiments that discovered the bottom and top quarks).
Unfortunately, there isn't one, because the process used depends on the specific model we use, and there are multiple models that we use to estimate quark masses. This is fundamentally because we can't solve the equations that describe the strong interaction directly, so we have to use approximations, and we need to use different approximations for different situations.
The plot thickens. The process is more complicated than I thought and it appears to be a very indirect method. I guess I can settle for the name of the process models used. No need to explain the process models any further unless someone would like to try in layman's terms. I can look up the models myself for more information.
Yes, it has to be because quarks are confined and we can't observe them directly, so we can't measure their masses directly the way we can for particles like electrons.
It's not even that simple. There probably isn't a "B" level reference that will explain this, but you could try here for a start:
http://pdg.lbl.gov/2011/reviews/rpp2011-rev-quark-masses.pdf
Whew, that is complicated. I wonder what the confidence level really is concerning the masses of the quarks? Has that been quantified by anyone? I am sure it must be an educated guess at best. Thanks for your help.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
