How do I calculate a planets mass?
  • Thread starter Thread starter Vetmora
    Mass Planets
To calculate the mass of fictional planets, knowing their diameter and distance from their sun is insufficient, as these values alone do not provide enough information without average density. The mass can be derived from the diameter and surface gravity using specific formulas that incorporate the universal gravitational constant. If moons are included in the fictional scenario, their orbital characteristics can help determine the planet's mass. Additionally, orbital resonances should be considered when creating planetary systems. Overall, average density values or mass values must be established for accurate calculations of mass and gravity.
Vetmora
Hi all,
I have just joined this forum to see if anyone here can help me out.
First off, I am creating fictional planets that orbit fictional stars.
I have given all of my planets a diameter and a distance from their sun. From this, I have managed to calculate their orbital periods and orbital speeds using Kepler's third law.
So using this criteria is it possible to calculate the mass of the planet?
Also, if possible, I would like to calculate their gravity as well.
Thanks in advance.
Astronomy news on Phys.org
No, the diameter and orbital radius do not provide enough information to determine the mass or gravity. Both of these values depend on the average density of the planet. However, knowing the mass and diameter of a planet does determine its surface gravity (or vice versa). Specifically (assuming the planet to be spherical), M=\frac{\pi{}D^3\rho{}}{6}g=\frac{4GM}{D^2} \Rightarrow{}g=\frac{2\pi{}GD\rho{}}{3}.
Where G is the universal gravitational constant, M is the mass of the planet, ρ is its average density, and D is its diameter. So, knowing any two of: mass, diameter, average density, and surface gravity is enough to determine the other two.
If you're creating fictional situations, is it possible to create fictional moons? As Isometric said, you can't determine the mass of the planets based off their orbits around the Sun. With moons, however, you can determine the planets mass using the moons orbital characteristics.
Ah, I figured it wouldn't be possible.
I suppose it would be possible to create fictional moons. Some of the planets already have moons but I haven't worked out any stats for them other than their diameter.
Thanks for the heads up guys.
Keplers law isn't strictly accurate to a true universal simulation. It is predicated on the star being the sun, and the mass in orbit of that star having zero mass.
someone posted in another thread:
formula for acceleration due to gravity
g = GM / (R + h)^2
G is the gravitational constant = 6.67300 * 10-11 m3 kg-1 s-2
M is mass of body
R is radius of body
h is height above the body
If that holds true,
g(sun) + g(planet) - (orbital velocity) = 0
(for a perfectly spherical orbit)
for any planet. Under Keplers law, g(sun) should be equal to orbital velocity, since the orbiting objects are massless.
The problem will persist with moons too, you still have to make up average density values (or mass values) for your planets and moons.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
