How do I calculate the area of a square with 490 mm2?
  • Thread starter Thread starter ladil123
    Area Calculation
To calculate the area of a square with an area of 490 mm², one must determine the length of each side, which is found by taking the square root of the area. The square root of 490 mm² is approximately 22.14 mm. The discussion reveals confusion regarding the shape in question, as the provided image may not accurately represent a square. Clarification is needed on the dimensions and shape being analyzed. Ultimately, understanding the basic geometric principles is essential for calculating area correctly.
ladil123
Hello!
This is pretty easy but i´m failing...
The area of this "square" should be 490 mm2 .
What the proper way to do this..., I guess its simple geometry but for the moment I am drawing blank...
Mathematics news on Phys.org
Something is wrong in your image, when I consider the number all the way at the bottom to be the length of a side... using Pythagoras to calculate the diagonal length doesn't give me the indicated value.
Is it really a square? What precisely measures 22.3?
No, its nor really a square. Yes, it was a pretty crappy picture, but I got to the solution on my own. thanks for the help
I need help with normal shape area. Anyone?
WadeS, welcome to PF :smile:
It would have been best to ask your question in a brand new thread, since it appears unrelated to what was asked here.
That being said, what shape is it you need help with finding the area?:confused:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
