How do I calculate the diameter of a cyclinder using F= P x A ?
  • Thread starter Thread starter wolfmanwm
    Diameter
To calculate the diameter of a cylinder using the formula F = P x A, first rearrange the equation to find the area A as A = F / P. Given a force of 2000 Newtons and a pressure of 2.5 N/mm², substitute these values to find A. The area of a circle is expressed as A = (π/4) x D², allowing you to solve for the diameter D. By substituting A back into the equation, you can derive the required diameter for the pneumatic cylinder.
wolfmanwm
How do I calculate the diameter of a cyclinder using F= P x A ??
I need to be able to state the diameter of a pneumatic cyclinder using F= P x A
I have the following given information;
This is a lift with the required force being 2000 Newtons.
The pressure applied to the system is 2.5N/mm2
So I need an answer to the calculated diameter of the cyclinder required to make the lift work from the given inforation.
What do I need to do with the 2.5N/mm2 ? Do I need to use 3.4 (∏) to times the 2.5?
Thanks, Wayne
Use algebra to solve your equation for A in terms of F and P. Substitute the data to find A. What is the equation for the area of a circle A in terms of its diameter D?
