How Do I Calculate the Enthalpy of Isooctane at 500 K?
  • Thread starter Thread starter siddharth23
    enthalphy
The discussion revolves around calculating the enthalpy of isooctane at 500 K, focusing on the methodology and assumptions involved in the calculation process. The scope includes theoretical and mathematical reasoning related to thermodynamics.
  • Homework-related, Mathematical reasoning, Technical explanation
  • One participant suggests calculating the enthalpy up to the boiling point, then using the latent heat of vaporization, followed by calculating enthalpy to 500 K using the formula h = mCpΔT, questioning whether the same value of Cp should be used throughout.
  • Another participant asks for clarification on the specificity of the question, noting that it may be free form or approximate.
  • A different participant points out that the question specifies calculating enthalpy on a kJ/kmol basis.
  • Some participants mention the lack of constraints beyond units, implying flexibility in the approach to the problem.
  • Several participants request more information or the complete problem statement to better understand the context.
Participants express uncertainty regarding the completeness of the problem statement and the methodology for calculating enthalpy. There is no consensus on the approach to take, as multiple viewpoints and requests for clarification are present.
The discussion highlights limitations in the provided information, including missing assumptions and the need for a complete problem statement to guide the calculation process.
siddharth23
✱✱ member reminded to use the template provided ✱✱
I have to calculate the enthalpy of isooctane at 500 K.
Isooctane is a liquid at room temperature and whenever enthalpy is to be calculated, it is from the standard state (278 K temperataure, 1 atm pressure).
Do I calculate enthalpy upto boiling point, then use latent heat of vaporization and from that point calculate enthalpy upto 500 K using h = mCpΔT ? And if so, do I use the same value of Cp throughout?
What's the question say? Is it specific? Free form? Approximate?
It says to calculate the enthalpy of isooctane at 500 K on a kJ/kmol basis
You haven't been given any constraints beyond units, so you are free to do as you wish.
You haven't given the exact and complete problem statement.
Can you post the question again with more information ?
15K
