How Do I Calculate the Power Required to Rotate a Cable Drum?
  • Thread starter Thread starter tamil_gce05
    Power Rotate
To calculate the power required to rotate a cable drum with a diameter of 50 inches and a weight of about 3 tons, one must consider the drum's kinetic energy at 30 RPM, as well as the effects of mass and geometry changes as cable is removed. Newton's second law can be applied to find the necessary power for acceleration to the desired speed. The use of needle bearings at both ends of the shaft can reduce the horsepower required, but the exact percentage reduction needs to be calculated based on friction and load conditions. Understanding these dynamics is crucial for selecting the appropriate electrical motor. Accurate calculations will ensure efficient operation of the cable drum system.
tamil_gce05
Hi All,
Cable drum, OD-50" weight abt 3 ton.. support by shaft horizontally.Both end of shaft is mounted on bearing. now i need to select electrical motor to rotate the this drum.
drum need to rotate constant 30 rpm speed..
please some one help to calculate the power required to rotate.
Zero horsepower, discounting friction and external forces on the drum.
You will need some power in order to accelerate the drum up to 30rpm. Not only that, but as the cable is taken off the drum its moment of gyration will change.
You can determine the power required to accelerate the drum using Newtons second law to find the drums kinetic energy at 30rpm. In order to maintain that speed you will need to know how the drums mass and geometry changes as cable is removed and the friction inflicted on the drum.
Hi,
Thanks for reply..
actually, drum rod is supported by both end needle bearings...because using bearing, HP required to rotate the drum get reduced or not...how much %..how to calculate that..
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
