How do I calculate the RMS and average voltage of a sine wave with a DC offset?
To calculate the RMS and average voltage of a sine wave with a DC offset, the average voltage is determined to be -6V, while the RMS voltage is calculated as 7.15V. The RMS calculation involves using the formula for the sine wave and incorporating the offset, ensuring the result is positive since RMS represents the DC equivalent for power delivery. The discussion also touches on integrating a half-rectified wave, emphasizing the need to account for offsets and the correct limits for integration. The participants clarify that the function does not need to be symmetrical within its period, but must be consistent from period to period for accurate calculations.
D44
I have to calculate the RMS and average voltage of a sine wave with a DC offset.
I have a peak to peak voltage of 11V and an offset which is -6V.
I have the average voltage as -6V and RMS voltage as 7.15V. I calculated the RMS as follows:
AC Vrms = 5.5/sqrt(2) = 3.89V
Vrms = sqrt(3.89^2 + 6^2) = 7.15V
Does this look correct?
Check your AC Vrms calculation. \frac{11}{2}\sqrt{2} \neq \frac{5.5}{\sqrt{2}}
EDIT: Oops. D44's result is correct. See below.
I thought RMS of a sine wave was Vpeak/sqrt(2)?
My apologies. You are correct. I blame it on lack of coffee :smile:
You're result is fine.
I've accidently just clicked on report instead of new reply, so whoever runs this site will wonder why I'm talking about voltages. Sorry about that :/
No problem. Coffee time for me too I think :) So the results look ok? How is it that I get a positive RMS? The way I see the wave is that the average is -6V, it reaches a peak of -6+5.5 = -0.5V and has a minimum of -6-5.5 = -11.5V. How is it that the RMS could be 7.15V?
RMS is always positive. It represents the DC equivalent for power delivered.
RMS of a function is calculated as the square root of the mean of the square of the function (hence R M S). Your voltage function can be written as:
f(\theta) = \frac{V_{pp}}{2}sin(\theta) - 6
and the RMS value:
V_{rms} = \sqrt{\frac{1}{2 \pi} \int_0^{2 \pi} f(\theta)^2 d\theta}
If you perform the integration you should obtain the same, positive value as you did before. Squaring the function ensures that the result must be a positive value.
Thanks, that's great!
Can I also ask...
For the half rectified wave I spoke about the other day, again if I was wanting to integrate, given peak current as 11A, Tpulse as 0.02s and Tperiod as 0.035s, I'm thinking that my function would be 5.5sin(50*pi*t). So I integrate this with respect to t? Between the limits of 0 and 0.02? Then divide by 0.035?
Can I also ask...
That function also had offsets that you'd need to calculate first and apply. If you specify all the times in milliseconds then you'd have something like:
f(t) = A sin(\frac{2 \pi}{35} t - \phi) + Vo
Where \phi is an angular offset for the sine function, and Vo the voltage offset that shifts the base of the pulse up to the 0V level.
\phi can be obtained directly from the Δt value in the above figure. The offset voltage, Vo, requires a bit more work: Note that A + Vo = 11, and Vo = Asin(\phi).
This is the image of the waveform that I have. So I need to find the average and RMS in order to find form factor.
Yes. It corresponds to the image that I posted above if you 'chop' the wave off along the horizontal zero line (time axis as shown).
But if the 2 portions of a single period aren't identical, how does this effect the function? That's what's stopping me getting round to the integration part
The function does not have to be symmetrical within its period, it only has to be identical from period to period.
If you write the expression for the full, untruncated-at-zero function, then integrate over only the sections that are greater than zero, then you'll be okay. For the graph that I posted above, that function is:
And the integration bounds would go from 0 to 22 (milliseconds) to include just the pulse.
I'm struggling with this. The 2nd pic I put up is the unaltered version of the wave.
In this case, phi would be 0 and Vo would be 0? So I'm just integrating Asin(((2*pi)/35)t)?
If you approximate the pulse with a half cycle of a true sinewave then you would have
f(t) = 11 sin(\frac{2 \pi}{2 \times 22}t) ~~~~~ 0 \leq t \leq 22
But this will be an approximation only, one that gets worse as the offset voltage gets larger. This is because while the half-sinewave is everywhere concave from below, a full sinewave alternates from concave to convex in shape at its zero crossings. So the function of a pulse created by rectifying an offset sinewave is not the same thing as stretching a half a sinewave to the same amplitude.
