How Do I Create a Sodium Acetate Buffer Solution with a Specific pH?
  • Thread starter Thread starter Rapidshift
    Buffer
This discussion focuses on creating a Sodium Acetate buffer solution with a concentration of 0.25 mol L-1 at a pH of 6.8, utilizing Acetic acid and Sodium Hydroxide as reagents. The Henderson-Hasselbalch equation is crucial for determining the required ratio of Acetic acid ([CH3COOH]) to Sodium Acetate ([CH3COONa]). The correct formulation of the equation is pH = pKa + log [CH3COONa]/[CH3COOH], which helps in calculating the necessary concentrations to achieve the desired pH.
  • Understanding of buffer solutions and their components
  • Familiarity with the Henderson-Hasselbalch equation
  • Basic knowledge of acid-base reactions
  • Ability to perform logarithmic calculations
  • Calculate the specific amounts of Acetic acid and Sodium Acetate needed using the Henderson-Hasselbalch equation
  • Explore the concept of buffer capacity and its implications in solution preparation
  • Investigate the effects of temperature on buffer pH stability
  • Learn about alternative buffer systems for different pH ranges
Chemistry students, laboratory technicians, and anyone involved in preparing buffer solutions for experiments or industrial applications.
Rapidshift
Hello!,
I have encountered a problem relating to buffer solutions. The question states that I am to make a Sodium Acetate buffer solution of 0.25mol l-1, at pH 6.8. The reagents used to make the buffer solution however, is Acetic acid and Sodium Hydroxide. The pKa of Acetic acid is given as 4.75. I need to calculate the amounts (in moles) of acid/salt present in the buffer at the desired pH.
So far, all I got is the balanced reaction:
CH3COOH + NaOH <--> H2O + CH3COONa.
Where do I go from there?
Edit: I am aware of the Henderson-Hasselbalch equation but I do not know how the values fit in save for the pH and pKa. The final concentration is know (sodium acetate) but there are no values for the acid or the base, also, the Henderson-Hasselbalch equation is probably more useful for finding the pH of known solution concs.
So, I do not know how to proceed!
Chemistry news on Phys.org
From the Henderson-Hasselbalch equation you should be able to figure out the ratio of [CH3COOH]/[CH3COONa] required for the buffer to be pH 6.8. Since you know that [CH3COONa] + [CH3COOH] = 0.25 mol L-1, you have two equations and two unknowns.
Well using the Henderson-Hasselbalch equation,
6.8 = 4.75 + log [CH3COOH]/[CH3COONa];
log [CH3COOH]/[CH3COONa] =2.05
After which, I approach a problem!
means that
[CH3COOH]/[CH3COONa] = 102.05
Because of the definition of a logarithm.
But, you've got another problem, you've confused the signs on the HH equation. It should be:
pH = pKa - log [CH3COOH]/[CH3COONa]
or
The way to remember this is to check whether the equation makes sense with what you know about buffer systems. If [CH3COOH] is greater than [CH3COONa] then the pH of the buffer will be below the pKa of the acid and vice versa. The original way you had set up the equation, the former statement would not have held.
9K
9K
9K
