Voltux
- Messages
- 29
- Reaction score
- 3
I've been trying to figure out why my DC subtraction amplifier is not working, and am completely baffled. I have set up an op amp with no feedback resistors with voltages applied to both the inverting and non-inverting inputs as specified below. I previously had the op amp setup with a 10x gain differential op amp following this circuit and obtained similar results. I tried searching and attempting the calculations for the op amp, and reading up on them in a couple books I had but I can find no explanation as to why this would not work. I used values of 5v, and 1v so that it would not be operating near the rail, and should have a gain of 1 since no resistors are added.
The Op amp output voltage should be Vo = Av*V1-V2 where V1 is the noninverting, and V2 is the inverting inputs. Av (Voltage Gain) = 1; therefore 5v-1v = 4 Vout is expected.
Op Amp: TL072CP & LM358
Supply Voltage +10v (Single Supply)
Inverting Input Voltage Applied: 1v DC
Non-Inverting Input Voltage Applied: 5v DC
Output Voltage Measured: 9.6V DC for TL072CP, 8.9v for LM358
