How do I go about the calculations for an air conveyor?
To calculate the design for an air conveyor similar to an air hockey table, it's essential to define the specifics of what will be conveyed, including the weight, dimensions, and surface characteristics of the items. Understanding the principles of hovercraft equations can aid in developing an efficient prototype that minimizes compressed air waste. Key calculations include determining the average pressure needed to float the objects, the minimum flow rate, and the plenum pressure. Additionally, consider how to manage air supply to unused sections of the conveyor. Gathering detailed information on the items and their interaction with the conveyor will facilitate accurate calculations and design optimization.
Luchee
TL;DR Summary
I am trying fabricate a contactless air conveyor.
How do I go about the calculations for an air conveyor that has the same working principle as an air hockey table?
The conveyor should not he bulky seeing as it is a prototype.
Please help me.
Welcome to PF.
You are starting with a small prototype, but will find later that, at a realistic scale, the game changes entirely. You must develop an understanding of the principles, and restrict your design to a conveyor that can be operated economically, without a waste of compressed air. Calculations will be needed to select the character or topology of the system. Calculations will then be needed to optimise the selected design.
The design complexity can be reduced by considering the possible answers to the following questions.
1. Will there be a standard moving puck or tray to support all loads, or will the items moved have an integrated puck, and so be restricted to fit the conveyor line ?
2. How will items be propelled to move along the line ?
3. How will you reduce the air supply to parts of the conveyor bed that are not being used ?
Luchee said:
TL;DR Summary: I am trying fabricate a contactless air conveyor.
You start by defining in detail exactly what you are conveying:
1) What are you conveying?
2) How heavy are they?
3) What are the dimensions of the surface of the objects in contact with the table?
4) How flat is the surface in contact with the table?
5) How rough is that surface?
6) Is the object porous?
7) Does the table need to move the objects, or merely float them?
8) What are the table dimensions of your prototype, and the finished table?
Use that information to calculate:
10) Calculate the average pressure to float the objects.
11) Calculate the minimum flow rate under the objects.
12) Calculate the plenum pressure.
13) Calculate the air flow through the uncovered holes (or use air table check valves).
14) Calculate total air flow.
Answering questions 1 through 8 above will give you the information to answer 10 and 11. I suggest that you give detailed answers to questions 1 through 8, then we can help you from there.
Thank you. I will start up on the findings and get back to you. Thank you very much
if you have any updates in your work would love to get some info will help so much
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
