How do i make chemicals by equation?
  • Thread starter Thread starter Klacid
    Chemicals
4 replies · 3K views
Klacid
Hey guys i wanted to know how make some chemicals when i have an equation, for example:
Chemistry news on Phys.org
First of all, you don't have any equations in the graphic above. These are called the molecular formulas for the various compounds shown.
A typical chemical formula, or reaction, looks like this:
A + B → C + D,
where A and B are the molecular formulas of the reagents, and C and D are the molecular formulas of the reaction products.
There are many different chemical reactions which are studied in chemistry. Some of these reactions can be quite dangerous if proper safety precautions are not employed.
Study some chemistry and then come back if you have any questions.
1- Although these molecular formulae would be recognised as the compounds named, it is not always the case that a molecular formula represents a single compound. It could represent several isomers with different structures.
2 - How you make a compound depends on what precursors you have. In general you can't just mix the elements in the required proportion, heat it and hope to get what you want. Strangely enough the compounds you list are more likely to be starting points for the production of other compounds. (Well glucose certainly; butane and octane are mainly fuels, though they could be partially oxidised to produce more reactive compounds.) They would generally be obtained from a biological source (glucose) or petroleum (butane and octane.)
Ok thanks guys, and last question, when i learn chemistry, is that possible i will know how to make equations from a molecular formula?
Yes, the molecular formulae help you work out the number of molecules of each substance to put in the equation.
When you make equations, the molecular formulae tell you what numbers to put in, but they don't help you know whether the reaction is likely. If you know that a reaction works, it simply gives you the correct quantities. For example, it is possible to make butane from pentanoic acid by removing CO2, using soda lime. The overall reaction is:
Pentanoic acid + Sodium Hydroxide -> Butane + Sodium Carbonate + water
C5H10O2 + 2 NaOH -> C4H10 + Na2CO3 + H2O
