How Do I Simplify These Tricky Integral Calculations?
  • Thread starter Thread starter rjs123
    Integration Stuck
rjs123
1. ∫(√4x² + 9)/x4
using u = atanθ
x = 3/2tanθ
dx = 3/2sec²θ
I plugged x in and am stuck on simplifying
2. ∫x²/√25 - x²)
u = asinθ
x = 5sinθ
dx = 5cosθ
Again, plugged x into original equation cannot simplify
3. ∫2x^3 - 4x - 8/(x² - x)(x² + 4)
got stuck midway through this problem...
2x^3 - 4x - 8 = A(x-1)(x² + 4) + B(x)(x² + 4) + Cx + D(x)(x-1)
let x = 0 A = 2
let x = 1 B = -2
You need to know your trig identities. For example, in the 2nd one:
\int \frac{x^2}{\sqrt{25-x^2}} dx
If you make the substitutions you get
\int \frac{25\sin^2 \theta \cdot 5\cos \theta}{\sqrt{25-25\sin^2 \theta}} d\theta
If I factor out the 25 in the denominator:
\int \frac{25\sin^2 \theta \cdot 5\cos \theta}{\sqrt{25(1-\sin^2 \theta)}} d\theta
... do you recognize anything?
rjs123 said:
3. ∫2x^3 - 4x - 8/(x² - x)(x² + 4) dx
Don't forget the dx.
let x = 0 A = 2
let x = 1 B = -2
Are you trying to use partial fractions? Expand the right side by multiplying out the polynomials, and after grouping like terms, equate the coefficients. For example, you'll see an x3 term on the right side. Set its coefficient equal to 2 (the coefficient on the left side).
rjs123 said:
1. ∫(√4x² + 9)/x4
using u = atanθ
x = 3/2tanθ
dx = 3/2sec²θ
Show us what you got. Also, you have omitted dx in your original integral, and dθ in your equation for dx. If you don't substitute for the differentials in trig substitutions, you won't be working with the right expressions.
rjs123 said:
2. ∫x²/√25 - x²)
u = asinθ
x = 5sinθ
dx = 5cosθ
You aren't using enough parentheses. As you have written your integrand, it would be interpreted as 2x3 - 4x - (
2x^3 - 4x - \frac{8}{(x^2 - x)(x^2 + 4)}
From the work you show below, that's not what you intended.
Again, you need more parentheses. The last expression on the right side above should be (Cx + D)(x(x - 1))
rjs123 said:
let x = 0 A = 2
let x = 1 B = -2
You can use these values to rewrite you equation above.
2x3 - 4x - 8 = 2(x - 1)(x2 + 4) - 2x(x2 + 4) + (Cx + D)(x(x - 1))
Pick a couple more values of x to solve for C and D.
I say nothing about your notation, but the first integral is it supposed to be
I= \int \frac{\sqrt{4x^{2}+9}}{x^k} \, dx [/itex]<br /> <br /> where k=4 ? If k=1, the integration is almost immediate. For k not 1 it gets messy as Mathematica shows (attachment)
thanks for the help, i reduced the denominator before plugging in x...led to my mistake
here is where i am stuck at now:
\int\frac {25\sin^2\theta}{5cos\theta} d\theta
im not sure which way i should go here.
rjs123 said:
1. ∫(√4x² + 9)/x4
using u = atanθ
x = 3/2tanθ
dx = 3/2sec²θ
Assuming you mean:
\int \frac{\sqrt{4x^{2}+9}}{x^4} \, dx
Using the substitution you suggested:
If x = (3/2)tanθ , then dx = (3/2)sec2θ dθ. Also 4x2 = 9tan2θ.
So, your integral becomes:
\int\frac{\sqrt{9\tan^2(\theta)+9}}{\displaystyle ({81}/{16})\tan^4(\theta)}\,\left(\frac{3}{2}\right)\sec^2(\theta)\,d\theta
=\frac{8}{9}\int\frac{|\sec^3(\theta)|}{\tan^4(\theta)}\,d\theta
Write the integrand in terms of sin & cos, then you should be fine. Don't forget to change back from θ to x.
\int\frac {25\sin^2\theta}{5\cos\theta} d\theta
Technically, that's:
\int\frac {25\sin^2\theta}{5|\cos\theta|} d\theta
Use sin2θ = 1‒cos2θ & divide each term by |cosθ|
Replace sin^2(theta) by 1 - cos^2(theta), and then divide both terms by cos(theta).
\frac{1-\cos^2(\theta)}{\cos(\theta)}=\frac{1}{\cos(\theta)}-\frac{\cos^2(\theta)}{\cos(\theta)}=\ \ ?
It's true that \int\sec(\theta)\,d\theta is a bit tricky.
\int \sec\theta \, d\theta = \int \frac{d\sin\theta}{1-\sin^2 \theta} =...
The last can be done either using the substitution \sin\theta = \tanh u or by partial fractions.
