How Do Magnetic Fields Influence Water Behavior and Flow?
Magnetic fields have a minimal effect on water due to its diamagnetic properties, but extremely powerful magnets could potentially influence water movement significantly. MagnetoHydroDynamics is a technology that uses electricity and magnets to control water flow, demonstrating practical applications of magnetic fields in fluid dynamics. Ferrofluid, a liquid containing iron oxide particles, can be manipulated by magnets, showcasing a more pronounced interaction with magnetic fields. Making ferrofluid at home is possible but requires careful handling due to its staining properties and the use of hazardous materials. Overall, while magnetic fields can affect water behavior, the effects are limited without extremely strong magnets or specialized fluids like ferrofluid.
Exavatar
Hi!
First: I need to know how much affect does a magnetic field or magnets in general have on water and can this affect be amplified.
Second: I need to know if it is possible to magnetize water and to what degree in order for it to be significantly affected by a magnetic field if possible.
Third: Is it possible for a magnetic field to control the flow of water, in terms of redirection in a controlled environment.
My knowledge on physics is not really high, so it what I am asking totally impossible and ridiculous I apologizes.
you can take two bags of water and hang them on a coat hanger, So you have a torsion setup
and if you have a pretty strong bar magnet, like a rare Earth one , if you hold it next to water after a little bit it will start to push the water bag around in a circle. And if your patient it will pick up speed.
Magnetic fields have a very tiny effect on water, due to waters diamagnetic value.
If you had extremely powerful magnets of the order of 10s of Tesla, then it may be possible to influence the motion water significantly.
@RocketSci5KN
Snap! I was about to find exactly the same video.
You may be interested in MagnetoHydroDynamics. This technology combines passing electricity through salt water in proximity to specifically oriented permanent magnets to provide some control of water flow. See wiki:
http://en.wikipedia.org/wiki/Magnetohydrodynamic_drive
You may also be interested in a NASA engineered fluid called Ferrofluid which is basically a liquid that has millions and millions of bits of iron oxide (usually magnetite) about 10 nanometers in size. When a magnet is moved by it, the fluid conforms to the magnetic field lines of the magnet it is near. The iron particulates are coated with a surfactant or 'soap' and suspended in some kind of oil called a carrier. Check out a bunch of YouTube videos below.
(these are called ferrofluid display cells and cost about 25$)
You can make some cheap ferrofluid by looking up 'make ferrofluid' on instructables.com*see link below. The medium to high quality stuff costs about 35$ for 60ml. [It’s really expensive] Making some high quality ferrofluid isn’t too difficult; I’m actually in the process of making some myself. However, it requires kerosene, oleic acid, magnetite (black laser printer toner), and ammonia. You will need a decent magnet (preferably rare Earth neodymium magnets) to see the effects nicely.
Layman’s term for ferrofluid is sometimes 'magnetic liquid' (although that’s not accurate, ferrofluid not made of little magnets).
Ferrofluid synthesis instructions:
http://chemistry.about.com/od/demonstrationsexperiments/ss/liquidmagnet.htm
Very low quality ferrofluid (but you get the idea): http://www.instructables.com/id/Make-your-own-ferrofluid-in-5-minutes/
WARNING! Remember to wear your ‘working clothes’ and handle ferrofluid in the back yard, because ferrofluid will permanently stain all clothing and most materials it touches. And DON’T drink it! Hopefully that’s obvious. Ferrofluid ‘sticks’ because the little bits of iron lodge into cracks and such on the materials it touches. Glass (or polished glass) is safe with ferrofluid as long as it’s not left on too long (hours to days...). Some ferrofluids contain kerosene, so don’t go sniffing it all the time; or leave it out for long periods of time or some of the fluid will evaporate (and make your mom mad because of the smell).
Follow all directions and safety instructions carefully.
Ferrofluid makes a really cool science project, and can be incredibly fascinating and educational when handled properly. The display cell link above is the best demonstration of ferrofluid for mad scientists and teachers.
Thank you all for taking the time and answer.:)
cheers!
*something I know what I'm talking about for once... lol (psst. don't tell the admins)
14K
13K
