How Do Slits and Gratings Create Light Patterns You See?
The discussion revolves around the behavior of light as it passes through diffraction gratings and slits, specifically focusing on the resulting interference and diffraction patterns observed. Participants explore the configurations of light sources, slits, and the observer's position in relation to the patterns formed on a wall or other surfaces.
  • Participants question the visibility of patterns when slits are placed between the observer and the light source, exploring the implications of reflection and the nature of the "screen" where light ends up. There are inquiries about the differences in diffraction patterns observed in front of and behind the aperture.
The discussion is active, with participants providing insights into the physics of diffraction and reflection. Some have offered theoretical perspectives, while others are seeking clarification on specific aspects, such as the nature of the images produced and the sensations experienced by the observer.
Participants are navigating assumptions about light behavior and the definitions of terms like "screen" in the context of diffraction and reflection. There is an ongoing exploration of how different configurations affect the observed patterns.
sparkle123
When you shine light through a diffraction grating/double slit/single slit, I understand that you see an interference/diffraction pattern on the wall, so that you have:
light source -- grating/slit ---pattern on wall
But if you put a grating/slits between your eyes and a light source, why do you see a pattern on the wall in the direction of the light source? i.e. the configuration
eyes --- slits --- light source --- pattern on wall
as opposed to
pattern on wall/eyes --- slits --- light source
Thanks!
Most likely light sources behind you, or reflection (if I understand your question).
How would reflection work?
If we go by vector diffraction theory we see that the field behind the aperture is
[tex]\vec{E}(\vec{x})=\vec{E}^{(0)}(\vec{x})+ \vec{E}^{(1)}( \vec{x} )-<br /> \vec{E}_{diff}(\vec{x})[/tex]
Where E^0 and E^1 describes the sources behind the aperture given a perfectly conducting plane at the aperture plane.
I'm sure you just want to cut the chase though. In the region behind the aperture, we see both the reflections of the source AND the diffraction pattern. So you can see, the diffraction pattern is produced both in front, and behind the aperture.
Are the diffraction patterns produced in front and behind the aperture the same? (so you see one image)?
Thank you! :)
First, where does the light actually end up? (what is the actual "screen" in this situation?)
Second, what kind of sensations would you expect this to produce?
Thank you! :)
The diffraction itself will be same, but the image will be different. Since detectors (such as eyes) measure the field's intensity, in the reflection case there are three terms that contribute to intensity as a function of position.
The light that goes through the slits hits your eyes so your eye is the screen?
So the light is reflected off your eyes?
Uhhh... your eye hurts?
But if there are two images, why do you only see one?
Thanks you guys!
  • · Replies 23 ·
14K
