How Can You Calculate Mass Using Force and Acceleration?
  • Thread starter Thread starter Balsam
    F=ma Mass
To calculate mass using the equation m = f/a, it is important to note that if both net force and acceleration are zero, the situation becomes mathematically indeterminate (0/0). In such cases, mass cannot be determined without applying a force to observe a resultant effect. Typically, mass is measured in static conditions by comparing it to known masses or through mass take-off methods. Measuring the mass of a moving object is more complex due to the need to evaluate the various forces acting on it. Accurate mass determination requires careful consideration of these factors.
Balsam
This is not a specific problem, I was just wondering how you would calculate the mass of an object. If given the net force and acceleration, how would you calculate it if the net force is 0N or the acceleration is 0m/s^2? Isn't the equation just m=f/a?
The equation m = f/a works fine as a way to determine mass. However...
0/0 is mathematically indeterminate. You can't say anything about the mass if you don't actually do anything to it (apply a force to observe a result).
Most people measure mass in a static situation, by comparing it with either a known mass or by doing what is called a mass take-off, where the mass of a complex assembly is estimated by adding up the masses of individual components.
Measuring the mass of a moving body is tricky. Accelerometers can tell you if the body is accelerating and in what direction, but how can you evaluate accurately the different forces acting on the body?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
