How Do You Calculate Resultant Forces in a Parallelogram of Forces?
  • Thread starter Thread starter manich43
    Forces
To calculate resultant forces in a parallelogram of forces, the component approach is recommended, where each force vector is broken down into its x and y components. By expressing the forces as Fv1 = fx1 i + fy1 j, Fv2 = fx2 i + fy2 j, and Fv3 = fx3 i + fy3 j, the resultant force can be found by summing the i and j components. The law of vector addition applies, allowing for the construction of a vector triangle or parallelogram to visualize the forces. This method effectively demonstrates that the resultant force can be determined from the combined components. Understanding this approach simplifies the calculation of resultant forces in physics problems.
manich43
Can someone show me how to calculate the resultant forces shown as RF N and R F 1on the attachment please, in simple terms.
2.I need to work out the following..."Three forces applying to one point,find the resultant force" (magnitude and direction to horizontal line) R F1 and R F N
3.Any help greatly appreciated.
Mark
Welcome to PF.
The approach that works best for me is the component approach.
What you have is a vector addition in x,y
So try taking each Force vector as
Fv1 = fx1 i + fy1 j
Fv2 = fx2 i + fy2 j
Fv3 = fx3 i + fy3 j
Then just add the i's and the j's and you have your resultant
F = (fx1+fx2+fx3) i + (fy1+fy2+fy3) j
Hi,
Dont really follow that.This is the first time i have seen a parallelogram of forces.Can you explain how I would find the resultant force in N for RF 1 and RF N on the diagram.
Many Thanks...Mark
Welcome to PF!
Hi Mark! Welcome to PF! :smile:
Forces are vectors, so they obey the law of vector addition …
that means that to add two vectors, you slide one so that it starts where the other one ends
in other words, you make a vector triangle …
but it comes out the same if you start both of them from the same point, and make a parallelogram (as in your diagram) …
to convince yourself that they're the same, just try sliding one of the sides of the parallelogram along to the opposite side :wink:
Thanks to all who replied,problem solved!
Mark
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
