How Do You Calculate Temperatures and Volumes in a Helium Gas PV Diagram Cycle?
mrmonkah
100 moles of very dilute He gas are taken through the cycly ABC, where BC is an isothermal process. If P(a) = P(c) = 1atm, P(b) = 2atm and V(a) = V(b) = 3m^3, Calculate T(a), T(b) and V(c)
eq1. PV = nRT
eq2. V = nRT/P
Am i right in thinking that i can plug in the values of P(a) and V(a) to get T(a) into eq1. and similarly for T(b)?
I have T(a) = 361k, T(b) = 722k and V(c) = 6m^3
This seems to straight forward to be correct... any help would be great.
Looks good, though I'm getting slightly different values for T(a) and T(b). You might want to recheck your calculation, and if you don't get slightly different results post your calculation of T(a) here. You are correct that T(b) is 2T(a), and V(c) is correct as well.
Did you use R=8.206 x 10-5 atm·m3/(mol·K)?
Hi Redbelly,
Ive submitted the work now. Unfortunately before seeing this post.
I actually converted my units to SI. And so used: R = 8.314J/(K mol)
Ive had some feed back in the past about sticking with the given units in some situations and not in others... and so i don't always head in the right direction. I am thinking in this example, stay with original units.
Cheers for the heads up.
Regards,
Dan
No problem. Since you've submitted the work, I'll mention that I had gotten 366 K for T(a), so you were pretty close, only 1.3% off. I suspect you used the approximation 1 atm = 100 kPa, instead of the more accurate 1 atm = 101.3 kPa.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
