How Do You Calculate the Force in Pool Ball Collisions Including Friction?
  • Thread starter Thread starter Bobolis
    Balls Collision
Calculating the force in pool ball collisions requires considering both linear and angular momentum, as well as the friction between the balls. The challenge lies in modeling the instantaneous collision force, which typically occurs over time in reality. The discussion emphasizes the need for a programming approach that incorporates the balls' linear and angular velocities to determine the collision force. While the motion of the balls is functioning well, the specific mechanics of ball-to-ball friction remain unclear. Additional resources have been suggested, but they may not fully address the complexities of this particular scenario.
Bobolis
I have a bit of time on my hands at the moment and being an avid pool fan I wanted to try my hand at programming a pool simulation. Now I have the balls moving correctly whether they are sliding or rolling but I am having a little trouble getting my head round the collisions.
Ideally I want the collisions to be modeled taking into account the friction between balls and therefore use the conservation of angular momentum as well as the conservation of linear momentum. I have tried looking up everything I can on the subject but I can't seem to work out how to model it. Everywhere seems to talk about the collision force acting between the two balls but I can't seem to work out how I get this force. I realize that in reality this force happens over a period of time but for the sake of simplicity I wanted to program the collisions to be instantaneous. So what I am asking basically is how do I find out the force acting between these two balls? As it's a programming problem I ideally want this in terms of information that I can use, such as the balls linear and angular velocity. Hope that makes sense.
Before I try to give an answer to your main query, how are you slowing down the balls? Have you been able to give spins to the balls?
Yeah, the motion of the balls is working fine with both linear and angular velocities. It calculates the change in position from it's previous state change (i.e. when a force is applied to it or when it changes from sliding to natural roll) as time elapses.
Have a look at http://www.gamasutra.com/features/20000516/lander_pfv.htm". You may find it helpful.
Yes I have read that but unfortunately it does not deal with ball - ball friction.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
