How Do You Calculate the Force of Gravity on a Spacecraft Above Earth?
To calculate the force of gravity on a spacecraft 6400 km above Earth's surface, use the formula Fg = GMm/r^2, where G is the gravitational constant, M is Earth's mass, m is the spacecraft's mass, and r is the distance from Earth's center. The distance r should be the sum of Earth's radius and the altitude above the surface. The force of gravity decreases with the square of the distance, meaning it is one-fourth at twice the distance from Earth. For accurate results, ensure to use the correct values for G and Earth's mass in the calculation.
shrtweez13
Calculate the force of gravity on a spacecraft 6400 km (1 Earth radii) above the Earth's surface if its mass is 1400 kg.
i started by using the Fg = GMm/d
and i plugged in the numbers so it looked like this
(6.67*10^-11)(1400)(?)/12800
i don't know what m should equal and i can't get past that much. thanks so much for helping.
You have the correct formula. One of the M's is the mass of the second object involved in the gravitational attraction, in this case the earth. Find the mass of the Earth in your data sheets, plug that in, and your done.
thanks so much!
i was also stuck on this problem if you can help me.
A car at the Indianapolis-500 accelerates uniformly from the pit area, going from rest to 300 km/h in a semicircular arc with a radius of 200 m.
Determine the tangential acceleration of the car when it is halfway through the turn, assuming constant tangential acceleration. Determine the radial acceleration of the car at this time. If the curve were flat, what would the coefficient of static friction have to be between the tires and the roadbed to provide this acceleration with no slipping or skidding?
i know you use the equation Ac = v^2/r but i don't know for which part to use it for. so i used 300^2/100
but i know that's not right and i have no idea where to go from there. thanks so much
This is not the correct formula. The correct formula (Law of Universal Gravitation) is:
F = \frac{GM_{Earth}m_{craft}}{r^2}
where r= Radius of the Earth + d (distance above surface).
Note the r^2 in the denominator. So all you have to really know to solve this problem is that the force would be 1/4 at twice the distance or 350 kg.
AM
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
