How Do You Calculate the Magnitude of a Vector in the Form Constant * (i + j)?
The discussion revolves around calculating the magnitude of a vector expressed in the form of a constant multiplied by the sum of unit vectors i and j. Participants are exploring the correct approach to determine this magnitude and addressing potential misunderstandings in their calculations.
  • Participants discuss the application of the Pythagorean theorem to find distances and question the correctness of their answers. There are inquiries about the proper method to calculate the magnitude, including whether to take the root of the sum of the squares of the coefficients of i and j.
Several participants are actively questioning their calculations and the assumptions underlying their approaches. There is a mix of interpretations regarding the magnitude calculation, with some suggesting that the common coefficient should be treated differently. Guidance has been offered regarding the use of absolute values in the context of the magnitude calculation.
Participants are working under time constraints and are encouraged to clarify their understanding of the problem setup and the mathematical principles involved. There is an acknowledgment of potential discrepancies in answers provided to automated systems.
adhiluhur
But as you can see, when I typed the answer on the answer column, the computer marked it as wrong. Please point out my mistake in 24 hours. Thank you.
What is the distance between M and O?
By simple Pythagorean theorem you can work it out to l^2 sqrt{2}
I get something different. Since the clock is ticking, how about
[tex]l \sqrt{2}[/tex]
I was writing the distance squared. So basically our answer for that is same.
Ahh.. nevermind me, I thought I saw it... standby please.
I think my answer is correct and the computer is wrong.
How about your last step? The answer you gave was the common coefficient of i and j. But to get the magnitude should you not take the root of sum of the squares of these coefficients?
Use more sets of parentheses at the beginning.
Enlighten me.
adhiluhur said:
Enlighten me.
What is the magnitude of the vector [itex]\boldsymbol{x} = \boldsymbol{i}+\boldsymbol{j} = [1,1]^\text{T}[/itex]?
When something is in the form Constant * ( i + j ) and you would like to find the magnitude of that
use abs ( Constant * ( i+j) ) = Abs(Constant ) * Abs(i+j)
what is Abs ( i + j ) ?
How would you interpret it ?
  • · Replies 44 ·
