How Do You Calculate the Mass of a Rod with Non-Uniform Density?
To calculate the mass of a rod with non-uniform density, the linear mass density is given by λ = 0.300x² + 0.500 kg/m. The mass can be found using the integral m = ∫(from x1 to x2) λ(x) dx, where x1 = 2.00 m and x2 = 3.00 m. To determine the center of mass, the formula x_{CM} = (1/m) ∫(from x1 to x2) x λ(x) dx is used. Understanding these integrals is essential for solving the problem accurately. Proper application of these formulas will yield both the mass and center of mass of the rod.
AstroturfHead
I'm having a hard time with this.
A long thin rod lies along the x-axis. One end is at x=2.00 m and the other at x=3.00 m. Its linear mass density λ = 0.300 x2+ 0.500, in kg/m. Calculate mass of the rod.
Can anybody help?
I take it you mean \lambda = .300x^2 + .500?
Note that
m = \int_{x_1}^{x_2}\lambda(x) dx.
--J
But then how would I find the center of mass?
The center of mass is just the weighted average of the density. You really should be able to look these formulas up on your own, or memorize them.
x_{CM}= \frac{1}{m}\int_{x_1}^{x_2} x \lambda(x) dx
--J
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
