How Do You Calculate the Tension in Cables Supporting a Suspended Loudspeaker?
  • Thread starter Thread starter Allura
    Cables Tension
The problem involves calculating the tension in cables supporting a suspended loudspeaker, with a focus on the forces acting on the system and the geometry of the setup. The subject area includes concepts from mechanics and forces in equilibrium.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss finding the angle of the cables using trigonometric functions and consider the relationship between the tension in the cables and the weight of the loudspeaker. There is uncertainty about the correct application of sine and cosine functions in this context.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the need to determine the angle of the cables, but there is no explicit consensus on the best method to proceed.
Participants are working under the assumption that the loudspeaker is in static equilibrium, and there is a focus on the geometry of the cables and the forces involved. The problem does not specify the angles or any additional constraints beyond the given measurements.
Allura
A 26.0 kg loudspeaker is suspended 1.9 m below the ceiling by two 3.0-m long cables that angle outward at equal angles. What is the tension (in N) in the cables? Assume that the local acceleration due to gravity is 9.80 m/s2.
I'm not sure how to approach this problem. I was thinking I would find the angle using cos -1 (1.9/3) and then using the angle to find T1?
mg/2 sin theta = T
What 1 angle = the other =.
Try that
Ok so I got 9.8x26kg/2 = 127.4 and do you mean sin-1(127.4)?
You need to find the angle of between the rope and the top of the building or w/e it's suspended on.
  • · Replies 19 ·
11K
