How Do You Convert MeV/cm^3 to Rads?
  • Thread starter Thread starter ~Sam~
    Convert
To convert MeV/cm^3 to rads, it's important to note that MeV/cm^3 cannot be directly converted to rads or Grays due to dimensional differences. Rads measure absorbed radiation per mass, while MeV/cm^3 measures absorbed radiation per volume. The correct approach involves converting MeV/cm^3 to Grays, which requires knowing the density of the material in question. Grays (Gy) are related to rads, with 1 Gy equal to 100 rads. Understanding these units is crucial for accurate radiation dose calculations.
~Sam~
Convert MeV/cm^3 to rads
I wish I knew..
I tried looking up the unit conversions, but find nothing that connects them, I know rads is connected to the Gray which is J/Kg but can't connect it to the MeV/cm^3. Any ideas?
Hi ~Sam~! :smile:
rad is the old cgs unit, gray (small "g") or Gy (= 100 rad) is the SI unit … see http://en.wikipedia.org/wiki/Gray_(unit)"
MeV/cm3 has the wrong dimensions, so you can't convert it to rad or Gy …
MeV/cm3 would convert to Gy times density (J/kg times kg/m3) :wink:
Gy measures absorbed radiation per mass, MeV/cm3 measures absorbed radiation per volume
