How do you find the magnitude of acceleration?
To find the magnitude of acceleration for a block on a frictionless surface with a net force of 4.0 N and mass of 2.0 kg, the correct formula is A = F_net / m. The initial misunderstanding involved calculating the force of gravity instead of focusing on the horizontal forces acting on the block. A free body diagram is essential for visualizing the forces, and it should clarify whether there are multiple forces at play. It is important to break down forces into their X- and Y-components when they are not aligned. Understanding these concepts is crucial for correctly determining the acceleration.
mikelison womack
. If F = 4.0 N and m = 2.0 kg, what is the magnitude a of the acceleration for the block shown below? The surface is frictionless.
F=MA +/- Mg
19.6[/B]
mikelison womack said:
3. The Attempt at a Solution
19.6
Please show your work so we can identify where you've gone wrong.
I really just multiplied the mass and the acceleration due to gravity and that was it .
Umm.. that shows you have not understood the question.
Your calculation finds the downward force that gravity exerts on the block. You are asked to find a horizontal acceleration, not a force, and not downward.
Can you draw a free body diagram, showing all the forces on the block?
Likes mikelison womack
i can draw the free body diagram but i still fail to understand what's going on.
Please either post the diagram or describe it in detail.
Is there a specific formula to calculate the acceleration in this case.
. If F = 4.0 N and m = 2.0 kg, what is the magnitude a of the acceleration for the block shown below? The surface is frictionless.View attachment 235121
Are there two 4.0N forces acting on the block, as the drawing suggests? If so, those are the forces you need to account for, not the force due to gravity (the block is on a frictionless surface).
F=MA +/- Mg
19.6[/B]
no
No. Please post or describe the FBD as requested.
no
So which one should not be there?
the one showing the angle
no
Then why does the drawing show two forces? As @haruspex said, which one shouldn't be there?
Mark44 said:
Then why does the drawing show two forces? As @haruspex said, which one shouldn't be there?[/QUOTE
I don't know
no
If that diagram is directly from your problem, then it appears that there is indeed 2 forces, each of 4 N, being applied to the block.
The formula doesn't change from problem to problem. It's just the normal acceleration formula ##A=\frac{F_{net}}{M}##. But you have to find the total net force, not just the individual forces.
Likes Delta2
so when you say find the total net force i need to add all the forces acting on the object?
Of course. But remember that forces only directly sum together if they are pointing in the same direction. Which they are not in this problem. How do you add two forces together that aren't pointing in the same direction?
I have no clue.
I have no clue.
Break the forces down into their X- and Y- components. Do you know how to do that?
Nope, I don't have the best physics teacher
Unfortunately it's not particularly easy to explain over a forum. Give this video a look and see if it helps:
Feel free to ask if you have any questions about this process.
Okay, thank you.
Okay, thank you.
is there an equation for magnitude.
Magnitude of what?
Do you have a textbook? Any halfway decent book would have some worked examples like the problem you posted.
