jacob117
- 4
A 129 kg satellite experiences a gravitational force by the Earth of 790 N. What is the radius of the satellite's orbit?
F=GM/R^2
jacob117 said:hey guys i need some more opinions on this problem...and i just took a guess at the formula...
To find the radius of a circle using a ruler, place the ruler across the center of the circle and measure the distance from one edge to the other. This measurement will be the diameter of the circle, and to find the radius, simply divide the diameter by 2.
The formula for finding the radius of a circle is r = d/2, where r is the radius and d is the diameter. This means that the radius is equal to half of the diameter.
Yes, you can find the radius if you know the circumference of a circle. The formula for finding the radius using the circumference is r = c/2π, where r is the radius and c is the circumference. This means that the radius is equal to half of the circumference divided by pi (π).
To find the radius of a circle using the Pythagorean theorem, you will need to know the length of the circle's diameter and the distance from the center of the circle to the edge (which is also the radius). Then, you can use the formula r² = (d/2)² - h², where r is the radius, d is the diameter, and h is the distance from the center to the edge.
The radius and the area of a circle are directly related. The formula for finding the area of a circle is A = πr², where A is the area and r is the radius. This means that as the radius increases, the area of the circle also increases, and vice versa.
