How do you find the volume of three dimensions.
  • Thread starter Thread starter randomss444
    Dimensions Volume
To find the volume of a three-dimensional object, multiply its dimensions together, as demonstrated with the values 2.52, 4.57, and 5.61, resulting in approximately 64.607004. This method is valid for box-shaped objects with right angles. It's important to consider significant figures and units in the final answer, as these factors may affect grading. Ensuring accuracy in these aspects can be crucial for homework assignments. The discussion emphasizes the straightforward nature of volume calculation while highlighting common academic considerations.
randomss444
2.52x4.57x5.61
All you have to do is multiply the three right
So the answer would be 64.607004?
Thanks
Hi randomss444! :wink:
2.52x4.57x5.61
If it's a box shape (with all the angles 90º), then yes. :smile:
(why is that worrying you? :confused:)​
Thanks
Correct.
However, does your teacher mark off points for either (1) the wrong number of significant figures, or (2) not including the units in the answer or calculation?
