How do you find the X-values of inequalites involving trig functions?
To find the X-values for the inequalities |sinX|<0.5 and |cosX|>0.5, one can utilize inverse trigonometric functions and graphing techniques. The intervals for sin(X) and cos(X) must be determined correctly, as initial assumptions about their ranges were incorrect. Drawing the graphs helps visualize where the functions meet the specified conditions. Additionally, solving |sin(x)| = 0.5 within the interval 0 to 2π allows for identifying critical points that divide the x-axis into intervals for testing. Overall, combining graphical methods with algebraic solutions provides a comprehensive approach to solving these trigonometric inequalities.
graphs
What values of X between 0 and 2 pie radians satisfy each of the following:
1. |sinX|<0.5
2. |cosX|>0.5
Well the values of X lie between
1. -0.5 < sinX <0.5
2. cosX< -0.5 and cosX>0.5
How do you find the actual values of X? Do you use inverse trig functions? I forgot all that. Please, someone show me how to find the X's. Thanks.
1. |sinX|<0.5
2. |cosX|>0.5
1. -0.5 < sinX <0.5
No, the values of x don't lie on those intervals. Those are the intervals where sin(x) and cos(x) lie.
Draw the graphs. You can easily see where the values of x are that work on the graph. Assuming you know what x gives sine or cosine of .5 it should be easy to write down the x intervals.
Right. I made a mistake sin(X) or cos(X)= F(X)=Y...No X's. .
Can I arrive to that algebraically?
You can use the inverse cosine and sine functions to get the principle values. You still need to get the others. Can you not get the "standard triangle" angles and their sines and cosines by drawing little triangles?
Solve |sin(x)| = 0.5 for 0 ≤ x ≤ 2π . Place the solutions on the x-axis. They divide the x-axis up into intervals. Since the |sin(x)| is a continuous function, |sin(x)| will be entirely above 0.5 or entirely below 0.5 in each interval, so pick a test point from each interval.
Thank you for the answers, people.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
