How do you calculate half-life for radioactive isotopes?
  • Thread starter boredooom
In summary, the conversation discusses how to solve a problem involving calculating the half-life of a radioactive substance based on its activity and number of atoms. The conversation also includes a discussion on the usefulness of certain information in solving the problem and provides a solution using the relationship between activity, number of atoms, and half-life.
boredooom
I got an exam tomorrow, and since I missed the last week, I don't really know how to solve questions like these:
1 gramm of Ra-226 radiates 3,7*10^10 alpha-particles in a second. Find out the half-life period of Ra-226.
We produce a radioactive Cu-64 and seal it. After 20 days, the activity is 20 Bq. What was the mass in gramm of the Cu-64 when we produced it?
Answers and explanations would be greatly appreciated, :approve:
Thanks,
Pear
1) You have the mass of the sample, so from this you can find the number of atoms in the sample. This, with activity, can be used to find half-life.
2)Reverse that for the copper (though you'll need to look up half-life for Cu-64).
i don't think i understand.. can you explain more please?
What don't you understand? If you don't know the formula for finding the number of atoms in a sample given its gram atomic weight and mass, you should be able to find it in your book. The same goes for half life if given the activity and number of atoms.
The problem is difficult because you are given useless information. Try doing it with this information:
1 gramm radiates 3,7*10^10 alpha-particles in a second. Find out the half-life
Half-life means you have 0.5g left
What part of the given information is useless?
You don't need to know which element or isotope is decaying.
You might want to rethink that. The half-life depends on the fraction of the available nuclei that decay each second.
I understand where you are coming from, but doing it that way would require doing an integral, which seems a few grades higher than the source of this question.
your way would be something like this (the E means 10 to the power of the next number):
(6.02E23)/226 = 2.66E21 atoms; the first number is the AMU equivalent of 1g
(3.7E10)/(2.66E21) = 1.389e-11 decaying per atom per second (each decay has a mass of 4)
I never really got the hang of integrals but this is the best I can do (which is wrong).
[tex]\int^{?}_{0} (4)(1.389E^{-11})(2.66E^{21})((1) - (1.389E^{-11}))^{t} dt[/tex]
= (0.5)(6.02E23)
It's confusing as hell. How do I subtract the amount of decayed atoms from the nondecayed?
= (0.5)(6.02E23)
The underlying principle is that the probability of anyone atom decaying in a small time interval dt is constant, so the rate of decay or activity A(t) is proportional to the number of atoms available for decay N(t)
A(t) = -dN(t)/dt = λN(t)
The minus is because N(t) is decreasing with time.
The function N(t) that satisfies this differential relationship is the familiar decaying exponential. It could be found by separating variables and integrating, but the result is well known, so you don't need to repeat that part of the derivation.
I think you do need all the information give, since you have to find lambda to find half life (or the mean-life of the decay).
All you need is the relationship between activity, number of atoms (implying you need the mass of the sample) and half life.
Activity = N*lambda = N*ln2/Half-life, so half-life = N*ln2/A. N = Avogardo's*mass/gram atomic weight, so
Half-life = Avogadro's number*mass*ln2/Gram Atomic Weight. Mass and atomic weight are given, so you don't need to use an integral, and you do need the isotope.
1. How do you approach solving a problem?
As a scientist, I use the scientific method to approach problem solving. This involves identifying the problem, formulating a hypothesis, designing and conducting experiments, analyzing data, and drawing conclusions.
2. What resources do you use to solve a problem?
I use a variety of resources to solve a problem, including scientific literature, previous research, and collaboration with other scientists. I also use tools such as computer software and laboratory equipment to collect and analyze data.
3. How do you ensure accuracy in your problem-solving process?
I ensure accuracy by carefully designing experiments and controlling variables. I also use statistical analysis to evaluate the data and draw reliable conclusions. Additionally, I conduct peer review and replicate experiments to verify results.
4. How do you handle unexpected results during problem solving?
Unexpected results are a natural part of the scientific process. I examine the data and try to determine the cause of the unexpected results. Sometimes, this may lead to revising the experimental design or conducting additional experiments. It is important to remain objective and open-minded when faced with unexpected results.
5. How do you communicate your problem-solving process and results?
I communicate my problem-solving process and results through scientific publications, presentations at conferences, and collaborations with other scientists. It is important to clearly and accurately communicate the methods and results of a problem-solving process to contribute to the advancement of scientific knowledge.
  • High Energy, Nuclear, Particle Physics
