How do you take the Fourier transform of sin(t)/t using Parseval's Theorem?
Moomax
Evaluate INT(|X(t)|^2) dt using parsevals theorem
where x(t) = (sin(t)cos(10t))/(pi*t)
parsevals theorem: int(|f(t)|^2 dt = (1/2*pi)INT(|F(W)|^2 dw
So I've tried several attempts at this problem and this is my latest:
first I use the fact that sin(x)*cos(y) = (sin(x+y)+sin(x-y)) /2
to get sin(t)cos(10t)/pi*t = (sin(t+10t) + sin(t - 10t))/(2*pi*t)
then I split it up into : sin(11t)/2t*pi + sin(-9t)/2t*pi
then what I was going to do was take the Fourier transform of each function here however, I can't figure out how in the world to take the Fourier transform of sin(t)/t
anyone have any ideas? thanks!
Do you know a function whose Fourier transform is \sin(\omega)/\omega?
I checked on my transform table and looked around online a little and didn't see any transform that equals sin(w)/w. If there was i'd use the f(w) <-> F(t) rule and then it could work for me. Does that transform exist?
Hint:
Compute the (inverse) Fourier transform of f(x), defined as:
f(x) = 1 for -L < x < L,
otherwise f(x) = 0
Yes, it exists and is one of the most fundamental transforms! If your table doesn't have it, I would get another table (seriously). Count Iblis' hint is right on the money.
By the way, \sin(x)/x is sometimes called sinc(x), so look in your table for that. Caution: some authors define sinc(x) = \sin(\pi x)/(\pi x).
ooohhhh now it makes sense! thank you! XD
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
