How Does a Homogeneous Fluid Behave in a Rotating Cylinder?
The discussion focuses on the behavior of a homogeneous self-gravitating fluid within a rotating cylinder, as outlined in Question 5-2 of Binney & Tremaine's "Galactic Dynamics." The gravitational force per unit mass is derived as \(-\nabla\phi = -2\pi G\rho_0 (x\hat{\bf x} + y\hat{\bf y})\), indicating a radial direction towards the axis. For part (b), the Euler equation is simplified under the condition of no pressure gradients, leading to the conclusion that the fluid is in equilibrium when the velocity \(v\) is set to zero in the rotating frame, as confirmed by the answer key.
  • Understanding of gravitational forces in fluid dynamics
  • Familiarity with Euler's equations in rotating frames
  • Knowledge of equilibrium conditions in fluid mechanics
  • Basic concepts of self-gravitating fluids
  • Study the derivation of gravitational forces in rotating systems
  • Learn about the implications of Euler's equations in fluid dynamics
  • Research equilibrium conditions for rotating fluids
  • Examine the concept of pressure gradients in self-gravitating fluids
Students and researchers in astrophysics, fluid dynamics engineers, and anyone studying the dynamics of rotating fluids in gravitational fields.
xnd996
Here is the problem: (Question 5-2 in Binney&Tremaine Galactic Dynamics)
Consider a homogeneous self-gravitating fluid of uniform density [tex]\rho_0[/tex] contained within a rotating cylinder of radius [tex]R_0[/tex]. The cylinder and the fluid rotate at angular speed [tex]\Omega[/tex] about the axis of the cylinder, which we take to be the [tex]z[/tex]-axis, so [tex]{\bf\Omega} = \Omega\hat{\bf z}[/tex].
(a) Show that the gravitational force per unit mass at distance [tex]r[/tex] from the axis is
[tex]\begin{displaymath} -\nabla\phi = -2\pi G\rho_0 (x\hat{\bf x} + y\hat{\bf y}), \end{displaymath}[/tex]
directed radially toward the axis and perpendicular to it.
(b) Euler's equation for the fluid in the rotating frame is
[tex]\begin{displaymath} \frac{\partial{\bf v}}{\partial t} + ({\bf v}\cdot\nabla) \bf v = - \frac{\nabla P} {\rho}- \nabla \phi - 2 \Omega \times{\bf v} + \Omega^2 (x\hat{\bf x} + y\hat{\bf y})\,. \end{displaymath}[/tex]
Find the condition on [tex]\Omega[/tex] such that the fluid is in equilibrium with no pressure gradients (i.e. no Jeans swindle).
My problem:
So I understand part a but I am having difficulty with part b.
There are no pressure gradients so you set [tex]\nabla P[/tex] which leaves you with
[tex]\begin{displaymath} \frac{\partial{\bf v}}{\partial t} + ({\bf v}\cdot\nabla) \bf v = - \nabla \phi - 2 \Omega \times{\bf v} + \Omega^2 (x\hat{\bf x} + y\hat{\bf y})\,. \end{displaymath}[/tex]
I know you are also supposed to set [tex]v = 0[/tex] (I know this because I have an answer key that says set [tex]v = 0[/tex]) but why?
My question:
What part of this question implies that [tex]v = 0[/tex]? Is it zero because it is in equilibrium? What does it mean for the fluid to be in equilibrium? I would like a little help with this concept please.
It seems to me that a rotating fluid creates a force and thus pressure. I imagine that to keep pressure either constant or zero, the velocity should be zero as well. I could be wrong though.
May be the fluid in the rotating frame is standing still.
v=0 in this frame.
  • · Replies 19 ·
