How Does a Speaker Produce 2 Instruments' Sounds Simultaneously?
A speaker can produce multiple frequencies simultaneously through the principle of superposition, where different sound waves combine to create a composite waveform. For example, a kick drum at 100Hz and a Shakuhachi flute at 5kHz can coexist as their individual sound pressures add together. The human ear performs Fourier analysis to separate these overlapping frequencies, allowing us to perceive them distinctly. However, this separation can fail if the system becomes non-linear, leading to distortion. Ultimately, the ability to distinguish between these sounds is a remarkable function of the brain, which machines struggle to replicate.
RipClaw
I am quite confused how a speaker can produce two or more different frequencies at the same time ?
Let's consider one instrument to be the thud of the kick drum
Let the second instrument be a Shakuhachi flute. (From Enigma Sadeness)
Let us have only one speaker( like in most of the headphones)
Now how is the speaker able to produce the sound of both the thud & the flute at the same time ?
Considering the sound of the flute to be 5KHz, and the kick drum to be 100Hz, how is the speaker able to move at both frequencies at the same time ?
You can have vibrations superimposed on one another.
They cant. As jaap de vries stated, you can only superimpose frequencies with a single speaker.
You can decompose any acoustic waveform into a sum of pure tones. This is called Fourier analysis, and it rests on the principle of superposition: you can simply sum up independent signals to get the resulting output, so long as the system is linear.
That is exactly the case you are asking about. The speaker output is the superposition of two frequencies, and your ear performs the Fourier analysis to separate the tones. This breaks down if the system turns non-linear (i.e., if you turn the volume up too high the sounds get distorted and fuzzy. You hear distortion products that aren't present in the original signal.) All is good when the system is linear.
The signals (in this case, the pressures) of both instruments add in the speaker just as they already added in the amplifier, in the microphone, and in the air - and as they add in your ears.
The miraculous part of the operation is not that they add, but that your brains is capable of separating them. This is something machines do very badly.
You can also consider than your ear is decoding this complex waveform while using only a single diaphragm (not counting your other ear).
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
