How does an rotating loop determine direction of an station signal
The discussion focuses on how an automatic direction finder (ADF) in aircraft determines the direction of a station signal using a rotating loop antenna. It explains that the magnetic field of the incoming signal induces current in the loop, and when the loop's axis is aligned with the transmitter, no signal is induced. The key point is that the loop must be rotated to find the direction, with maximum current induced when the loop's area is perpendicular to the incoming signal. The discussion also highlights the 180-degree ambiguity in direction finding, which can be resolved by comparing the phase of signals received by two antennas. Overall, understanding the orientation and rotation of the loop is crucial for accurate signal detection.
rajeshmarndi
Considering the ADF (automatic direction finding) of an aircraft.
Assuming the transmitting aerial is vertically polarised i.e mag field lies in the horizontal plane.
And it is the magnetic field of the incoming signal that induces current in the loop.
And what would be the rotating plane of the loop (ADF) ?
I'm not getting a clear picture of the working, any help is appreciable.
Actually, the detector is not a loop, but many-loops coil with ferrite rod core. But in general it works the same.
As the loop axis points towards the transmitter, no signal is induced. So you just must tune your reciver, then rotate your antenna, and the moment when signal fades is when it points towards the lighthouse.
Of course, the direction is found with 180deg ambiguity. To resolve this ambiguity additional trick must be used, e.g. comparison of signal phase received by two antennas.
i have little confusion about the axis of the loop. If the axis is vertical and the loop area(vertical) rotate about its axis 360 deg, if I'm right i can see the loop induces current.
But then you said the when the loop axis points towards the transmitter which means the axis is horizontal and is perpendicular to the loop. And the loop is not rotated about its axis but the axis is being rotated in the horizontal plane, because of which the loop area vary to the signal and is max when the loop axis point towards the signal and therefore max current is induced.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
