How Does Atmospheric Pressure Affect Measurements in a Torricelli Barometer?
  • Context: Undergrad
  • Thread starter Thread starter Peter Dimitrov
    Law Pascal's law
The discussion revolves around the effects of atmospheric pressure on measurements in a Torricelli barometer, particularly in relation to Pascal's law. Participants explore the principles of pressure in fluids, the definition of Pascal's law, and the implications for understanding barometric measurements.
  • One participant questions why atmospheric pressure is not included in the pressure calculation at point A in the barometer, suggesting that it should be considered according to Pascal's law.
  • Another participant asserts that the tube is closed and contains a vacuum at the top, indicating that atmospheric pressure acts on the liquid at point B, causing it to rise at point A due to Pascal's law.
  • A participant clarifies that the barometer measures the unknown atmospheric pressure and references a Wikipedia article for further information.
  • There is a discussion about a common misconception regarding Pascal's law, with one participant stating that it describes pressure acting isotropically at a specific point, rather than uniformly throughout the fluid.
  • A participant expresses surprise at the previous comment and questions the conditions under which pressure is transmitted uniformly in a fluid, seeking clarification on the relationship to Pascal's law.
  • Another participant notes that pressure varies with depth in a gravitational field, indicating that uniform pressure transmission occurs only in static equilibrium without gravity.
  • One participant mentions that the pressure at point A should include both the hydrostatic pressure from the mercury column and the saturated vapor pressure of mercury above it, referring to the space above the mercury as a 'Torricelli vacuum.'
Participants express differing views on the application of Pascal's law and the role of atmospheric pressure in the barometer's operation. There is no consensus on the correct interpretation of these principles, and multiple competing views remain.
Participants highlight limitations in textbook definitions and the need for clarity regarding the conditions under which Pascal's law applies. The discussion also touches on the implications of gravitational effects on pressure in fluids.
Peter Dimitrov
I have a question about Pascal law. Recenly I was studying and I found this image in my physics book - a copy of the barometer which Torricelli used in his experiment (this is a redraw):
Where the blue thing is the fluid (mercury), while the black thing is the container.
According to my textbook, the pressure at point A is simply (p*g*h), the preasure caused by the fluid above it. However, why don't we also count the atmospheric pressure? Isn't it supossed to act in the entire fluid according to Pascal's law?
Thanks in advance!
Science news on Phys.org
There are no atmospheric pressure in the tube - it is closed tube and that white area at the top is vacuum. Therefore if you press liquid at the point B (atmospheric pressure), liquid will climb the tube at point A due to Pascal's law, until it counter weights the pressure;( here p*g*h is a weight of liquid in the tube).
A common misconception is that Pascal's law states that in a fluid at rest, pressure is transmitted throughout the fluid uniformly. This is not correct. Pascal's law actually states that at a particular position within a fluid at rest, the pressure acts the same in all directions (i.e., it is isotropic). This says nothing about how it varies from position to position.
Chestemiller, your comment surprises me! It appears my textbook has made a mistake with it's definition of Pascal's law! So, when is pressure transmitted though a fluid uniformly? And does this really have nothing to do with Pascal's law (what I mean is, do the special cases where pressure transmission is uniform follow from Pascal's law)?
(Sorry if some of these questions are unclear. English is a second language for me!)
Thanks for answers!
Thanks for answers!
In a gravitational field (i.e., with gravity), pressure varies with depth. So it is not uniform throughout the fluid. Pressure is transmitted uniformly throughout a fluid only if the fluid is in static equilibrium and there is no gravity. As I learned it, Pascal's law says only that, at a given spatial location in a fluid, pressure acts identically in all directions. That means that, if I place a tiny surface at an arbitrary location in a fluid that is in static equilibrium, the force per unit area is independent of the orientation of the surface, and acts perpendicular to the surface.
Thanks in advance!
there is mercury vapour above the liquid in the tube, the pressure at A is hρg + saturated pressure of mercury at the prevailing temperature.
The space above the mercury is called a 'torrecelli vacuum'
  • · Replies 18 ·
