How Does Conservation of Momentum Determine the Trajectory of Rocket Fragments?
The discussion centers on a weather rocket that explodes into two fragments after liftoff, raising questions about the conservation of momentum and the resulting trajectories. The lighter fragment ascends to a height of 530 m, while the heavier fragment's speed and direction post-explosion need to be determined. Participants emphasize the importance of applying the conservation of momentum principle rather than simply relying on specific equations. They suggest calculating the final velocities of both fragments using kinematics to solve for the heavier fragment's characteristics. Understanding these principles is crucial for accurately determining the motion of the fragments after the explosion.
DStan27
A 1550 kg weather rocket accelerates upward at 20 m/s2. It explodes 2.0 s after liftoff and breaks into two fragments, one twice as massive as the other. Photos reveal that the lighter fragment traveled straight up and reached a maximum height of 530 m. What were the speed and direction of the heavier fragment just after the explosion?
is there a way to use momentum and distance to find the speed. i know the second particle goes downward, but i can't figure out how to do this. I've tried everything i can think of.
thanks
should i be using mv = m1v1 + m2v2??
Is momentum conserved in this situation? If so, then you should be. Don't ask, "should I be using such and such equation?" Ask, "which physical principle applies to this situation?"
Anyway, have you figured out how to calculate v, the final velocity of the rocket? What about v1, the velocity of the less massive fragment? That should be simple kinematics in both cases. Once you have calculated those velocities, do you have the information you need to solve the problem?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
