I How does gravitational self-interaction affect the Milky Way Galaxy?
  • I
  • Thread starter Thread starter KurtLudwig
    Gravity Stars
Gravitational self-interaction is a complex topic, primarily described by the nonlinear nature of the Einstein Field Equation. The prevailing view is that such interactions have negligible effects on the shape of galaxies or the rotation curves of stars, leading to the postulation of dark matter to explain these phenomena. Some researchers, including Alexander Deur, propose alternative theories that challenge this standard viewpoint, but their ideas have not gained widespread acceptance in the scientific community. Additionally, the MOND theory suggests that General Relativity may not accurately describe gravity at low accelerations. The correctness of Deur's mathematics remains an open question, with limited confirmation from other physicists.
KurtLudwig
It is believed that gravity interacts with itself. I assume that gravity between stars increases. Does gravitational self-interaction change the galaxy's shape or increase the rotation curves of stars?
Astronomy news on Phys.org
More precisely, the Einstein Field Equation is nonlinear, which can be described as gravity interacting with itself. There is a lot of complexity lurking here; see this Insights article series for more information:
https://www.physicsforums.com/insights/does-gravity-gravitate/
No, gravity interacting with itself is not that simple.
The standard viewpoint at present is that any such effect is negligible, because gravity is too weak in this regime for any nonlinear effects to be significant. This is one of the chief reasons why the standard viewpoint postulates dark matter in order to account for galaxy rotation curves.
There is a body of research by Deur, among others, that claims that the above is not the case. This research has been discussed in a number of PF threads. I think it's fair to say that these proposals have not achieved much traction in the wider community, although research along these lines continues.
There is also the MOND viewpoint, which claims, in effect, that GR does not correctly describe the law of gravity for very small "acceleration due to gravity". (Many MOND proponents do not describe their research this way, but that is what it amounts to.)
Likes KurtLudwig, vanhees71, fresh_42 and 2 others
Thank you so much for taking the tine to answer my questions.
I attempted to understand your insights article "does-gravity-gravitate", however I am not at your level. One actually has to study physics at a graduate level and take classes in General Relativity to understand.
Is professor Alexander Deur mathematics correct? As you know, he is a reasearch physicist in particle physics at Jefferson Labs in Virginia.
That is an open question. If you search PF for his name you will find multiple threads discussing his work. I am not aware of any other physicist who has confirmed his calculations.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
