How Does Lenz's Law Apply to EMF in a Triaxially Bent Wire?
ghetto_bird25
A wire is bent into three circular segments each of radius r=9.2 cm. each segment is a quadrant of circle, ab lying in the xy plane, bc, in the yz plane, and ca lying in the zx plane. If a uniform magnetic field points in the positive x direction, what is in volts the magnitude of the emf developed in the wire when B increases at the rate of 3.4 mT/s?
http://edugen.wiley.com/edugen/courses/crs1141/art/images/c31/nw0500-n.gif
so what i used was faraday's law and lenz's law by using the formula
\epsilon=d(B A)/dt
and then since area (A) is constant you can bring it out. and area would equal 1/4\pir^{2} and the dB/dt is given. the only problem is that i don't know what to do with the components as you have the pieces on all three axis and how wood i deal with each component?
There are no components for the EMF. Your projected area seems right.
Just multiply A and dB/dt.
oh so jus do it for each section and add it up or make it 3/4pi*r^2 time dB/dt
No. The projected area area for the flux is just the pi*r^2/4.
oh ok thanks alot
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
