How Does Rocket Propulsion Calculation Work with Changing Mass?
The discussion revolves around understanding the rocket propulsion calculation involving changing mass. The key equation used is vf = vi + ve(ln(Mi/Mf)), where the user is confused about the ln(Mi/0.5Mi) term. It is clarified that this can be simplified to ln(2), as the two "Mi"s do not cancel but rather lead to the natural logarithm of the ratio. The final answer, after plugging in the values correctly, aligns with the example's result. This clarification resolves the user's confusion regarding the calculation process.
webren
Hello,
I am not understanding how the book got it's answer from the supplied rocket propulsion example.
"A rocket moving in free space has a speed of 3.0 x 10^3 m/s relative to the Earth. Its engines are turned on, and fuel is ejected in a direction opposite the rocket's motion at a speed of 5.0 x 10^3 m/s relative to the rocket. What is the speed of the rocket relative to the Earth once the rocket's mass is reduced to half its mass before ignition?"
The book uses the equations vf = vi + ve(ln(Mi/Mf)) to solve the problem where ve is exhaust velocity and Mi is initial mass of rocket plus fuel and Mf is final mass of rocket plus remaining fuel.
The example plugs in the known values to get:
3.0 x 10^3 m/s + (5.0 x 10^3 m/s)ln(Mi/0.5Mi) which equals 6.5 x 10^3 m/s.
I understand everything in the equation but the ln(Mi/0.5Mi) part. Because there are two "Mi"s, do they cancel out and leave you with ln(1/0.5)? By doing that, you come to another answer rather than the example's answer.
If anyone could clear this up for me, I would appreciate it. Thank you.
1. Sure you used the natural logarithm?
2. If you did that already Try with ln(2) rather than ln(1/0.5) and see what you get.
That is correct. You can write it either as ln(1) - ln(0.5) = -ln(0.5), or in a simpler way as ln(2). Both are same numerically.
I get the example's answer by doing that.
Got it. Thanks for clearing that up.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
