How Does Temperature Affect Sound Wave Velocity in Air?
The discussion centers on the relationship between temperature and the velocity of sound waves in air, specifically the claim that a 1 degree Celsius increase results in a 0.6 m/s increase in wave velocity. This relationship is based on the principle that sound velocity is proportional to the square root of absolute temperature in Kelvin. The confusion arises from the perception that the difference in velocity changes is smaller at higher temperatures due to the square root function. However, it is clarified that this approximation holds true within a specific range of temperatures, making it a valid simplification for practical purposes. Understanding this context resolves the initial confusion regarding the uniform increase in velocity across different temperature ranges.
TP9109
Apologies if this is a question with a basic answer, I'm coming back to physics after many years of being away from it! I read somewhere that for longitudinal sound waves traveling through air, if the temperature increases by 1 degree celsius then the velocity of the wave will increase y 0.6 m/s. They back this up by saying it is because v is proportional to sqrt of T, T in Kelvin. I don't understand this as if you square root the temp at 70 degrees and then square root the temp at 71 degrees, the difference between the two resulting numbers will be smaller than if the two temps were lower numbers e.g 30 and 31. So how can going from 70 to 71 degrees increase the velocity by the same amount as going from 30 to 31 as there is a square root involved giving smaller differences at changes in higher temperature values and larger differences between changes in lower temp values, so how can they say that the velocity increases by 0.6 m/s per degree regardless of whether a small or large temperature is involved?
Thanks for any help
Science news on Phys.org
Thanks for any help
It's an approximation that is valid only for a range of temperatures:
https://en.wikipedia.org/wiki/Speed_of_sound#Practical_formula_for_dry_air
Likes TP9109, sophiecentaur, etotheipi and 1 other person
I missed that part of the wiki page when I was googling answers, thanks for that it makes sense now
Likes russ_watters, berkeman and sophiecentaur
  • · Replies 42 ·
  • · Replies 47 ·
9K
