How does the two-slit experiment challenge our understanding of particle motion?
  • Thread starter Thread starter CoreyCapone
    Experiment Theory
The discussion centers on the two-slit experiment and its implications for particle motion, particularly challenging the concept of superposition. One participant suggests that the motion of electrons creates "air-waves" that influence their paths, but this idea is countered by the fact that the experiment yields consistent results even in a vacuum. Critics argue that the notion of air-waves fails to explain the observed phenomena, as electrons can still exhibit wave-like behavior without air present. Alternative interpretations of quantum mechanics, such as the de Broglie-Bohm interpretation, are mentioned as ways to understand particle behavior without relying on superposition. The conversation emphasizes that personal feelings about scientific theories should not overshadow empirical evidence.
CoreyCapone
I don't like the idea of superposition and have been thinking about this, would like to know what you guys think...
Imagine motion of a particle creates a wave in the particles surrounding it, much like your hand waving through the air creates a wave that would move dust that was floating in its path. Now imagine an "air-wave" like that is created by the motion of the electrons being shot at the two-slits. An electron is shot into motion towards the two slits, it's motion creates a wave in the particles/air around it, this "air-wave" passes through both slits, the "air-waves" now collide on the other side altering the path of the electron. Since the mass of electrons is so miniscule its path could be altered by the smallest amount of force.
Thoughts?
Welcome to these forums. Not liking something is not really a good way to do science. What counts is whether theory is in agreement with experiment, not whether it is pleasant or likable.
This can be simply ruled out by two things: First, the double slit works well (and even best) in vacuum with no air around to create such a wave. Second, if you think that the mass of electrons is so tiny compared to the stuff pushing it around, then why does this tiny little mass create such an air wave and push these particles with much larger mass around in the beginning? That does not really make sense.
By I don't like it I just meant that's the reason I'm thinking about this, but yeah i didn't think about the mass of the electron being small affecting the wave its motion would create, thanks
Welcome to the forum Corey!
Corey, not liking a scientific theory is no reason to object to it. Look at Fred Hoyle, just because he did not like the big bang theory, he wasted much effort developing the steady state model, only to have it turn out to be incorrect.
Well, air waves diverting the path of an electron isn't an acceptable explanation, as the same result would still be received if performed in a vacuum, without any air.
There is an interpretation known as the de Broglie-Bohm interpretation, that posits a wavefunction that is separate from the actual particle, and guides it.
A few physicists managed to create a macroscopic superposition in 2000. You can read about it here.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
