How far will it travel before it begins to fall to earth?
To determine how far a 30g bullet shot straight up at 724 m/s will travel before falling back to Earth, the time until it reaches its peak can be calculated using the formula t = 724/9.8, resulting in approximately 73.9 seconds. The height can then be found using the equation for height, which is 724t - 4.9t², by substituting the calculated time. For the electrical transformer design, to convert 12V AC at 50 amps to 120V AC, the secondary coil must have ten times the turns of the primary coil, which has 100 turns, resulting in a secondary coil of 1000 turns. The maximum power output from the transformer will equal the input power, but the output current will be one-tenth of the input current due to the voltage increase. Understanding these calculations is crucial for solving both physics and electrical engineering problems effectively.
robbie
Please help. The first question I don' know how to solve for distance because I don't have time in the formula. I've spent three days, and my friends and I are stumped, and had no-where else to turn, someone please help me.
1. You shoot a 30g bullet straight up at a velocity of 724m/s. How far will it travel before it begins to fall to earth?
2. If your car can generate electricity 12 v AC at 50 amps and you decide to supply power to your home during a storm outage. Please design a transformer to convert electricity to 120 v AC. Your primary coil has 100 turns. What is the potential output from the transfer?
Thanks for any help!
You know that the acceleration due to gravity is -9.8 m/s2 (negative since it is downward) so the speed at any time t is given by 724- 9.8t. The bullet will continue upward until its speed becomes 0. Then it will fall back as the speed becomes negative.
724- 9.8t= 0 gives t= 724/9.8= 73.9 seconds.
You also know that the height above the ground is given by (the "anti-derivative" of speed) 724t- 4.9t2. Plug 73.9 seconds in for t and calculate the height at that time.
___
___
Are you being asked for power output?
Your max power output from the transformer is the power in.
Your secondary turns must be 10 times more than your primary turns since you are looking for 10 times the voltage output.
Your current output is therefore one-tenth your current input..
