How great is the tension of the wire
  • Thread starter Thread starter gemz
    Tension Wire
To determine the tension in a 1.6m long steel piano wire with a diameter of 0.2 cm that stretches 0.3 cm, Hooke's Law can be applied. The formula for tension (T) is T = (Elastic Modulus * Area * Extension) / Length. The area of the wire can be calculated using the diameter, and the elastic modulus for steel is given as 2 x 10^11 N/m^2. By substituting the values into the formula, the tension can be calculated in Newtons. This approach is essential for solving the problem accurately in the context of the competition.
gemz
can anyone help me with this question.
A 1.6m long steel piano wire has a diameter of 0.2 cm. How great is the tension (in Newtons) in the wire if it stretches 0.3 cm when tightened ?
Assume an elastic modulus of steel = 2 x10^11 N/m^2)
I read the top were it says about showing your working that you do have.
I'm actually participating in a game not doing homework, it's a competition on an Australian Forum state versus state and I am the only person from my state so sometimes I need that little extra help and use helpful places like this.
Any help would be appreciated even a few steps in the right direction
Do you know Hookes law - The tension in a spring is directly proportional to the enlargement or compression. The string must be elastic and must be following Hookes law.
