How Is Friction Calculated for a Scrambler Car That Stops After 10 Meters?
  • Thread starter Thread starter pineapple629
    Friction
To calculate the friction for a scrambler car that stops after traveling 10 meters, the initial velocity is 1.25 m/s, and it takes 7 seconds to stop. The work done by friction is equal to the change in mechanical energy, represented by the equation W_f = -Mgh, where M is the mass and h is the height. The friction force is derived from the equation f = Mgh/X, leading to a calculation of f = (2kg * 10m/s² * 1m) / 10m. The discussion raises confusion about the value of 1.97, which appears to be related to the friction force calculation. Understanding the relationship between the variables and the equations used is crucial for accurate results.
pineapple629
we need to find the friction of our car after we launch it. it rolls to a stop at 10 meters.
http://home.comcast.net/~jay7042/physics.bmp
initial velocity after it laucnhed is 1.25 m/s
distance traveld 10m in 7s
we need to find the friction and efficiency of the car
Use energies. The only non-preserving force that operates in the system is the friction, and its work is equal to the change of mechanical energy of the whole system:
W_f = \Delta E_m = (\Delta E_k) + (\Delta E_p)
-fX = (0 - 0) + (0 - mgh) = -Mgh
Where M is the mass of the weight, and X is the total distance the car travels (1m + 10m), assuming there is also friction in the acceleration area (the 1m inside the structure). If there is no friction in that segment, then X is just 10m.
we are only going to calculate the 10m after it launched. i plugged my numbers into the bottom equation as best as i could and got -.023*10 = (-.178*9.8*1) = 1.97 now I am confused what 1.97 is
Where did you come up with 0.023N as the friction force? I thought that's what you were going to find.
-fX = -Mgh
Therefore:
f = \frac{Mgh}{x} = \frac{2kg10\frac{m}{s^2}1m}{10m}
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
