How is Mechanical Energy Conserved in a Spring-Block System?
  • Thread starter Thread starter ajmCane22
    Conservation
In a spring-block system, mechanical energy is conserved as the block compresses the spring. The kinetic energy of the block is calculated using the formula 1/2mv^2, yielding 0.431 J, while the spring potential energy is determined using 1/2kx^2, also resulting in 0.431 J. At maximum compression of 4.15 cm, the block's velocity is zero, indicating that all mechanical energy is stored as potential energy in the spring, totaling 0.431 J. The total mechanical energy remains constant throughout the compression process, with kinetic energy decreasing and potential energy increasing until maximum compression is reached. The discussion emphasizes the importance of understanding energy transformations in the system.
ajmCane22
A 1.10 kg block slides with a speed of 0.885 m/s on a frictionless horizontal surface until it encounters a spring with a force constant of 500 N/m. The block comes to rest after compressing the spring 4.15 cm.
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of (a) 0 cm, (b) 1.00 cm, (c) 2.00 cm, (d) 3.00, (e) 4.00 cm.
For the potential energy of the spring I used 1/2kx^2 to get 0.431 J, and for the kinetic energy of the block I used 1/2mv^2 to get 0.431 J. So wouldn't the total mechanical energy of the system be:
PEspring + KEblock = 0.431 + 0.431 = 0.862 J? I tried that but am getting the answer wrong.
Please help
For compression, you might need to put the work done by the spring as negative. Since I think the convention is that the work done by a spring in extension is positive.
So then the total work would be zero?
Actually they told you that when x = 4.15 cm, v=0, so at that point Etotal=PE. So it would just be the 0.431 J. At any other point before the maximum compression of 4.15 cm, Etotal= KE + PE. (It is this at any point, it is just at the max compression, KE=0)
I was making it so much hard than it needed to be. I finally got it. Thank you!
