How is the Tension in a Rubber Band Related to Thermodynamics?
The discussion focuses on the relationship between the tension in a rubber band and thermodynamics, specifically using the thermodynamic identity dU=TdS+fdl. The tension force F is expressed as a partial derivative of the entropy, leading to the equation f=dU/dl - TdS/dl. The participants successfully derived the necessary equations to compute tension in terms of length L, temperature T, number of links N, and link length l.
  • Understanding of thermodynamic identities and their applications
  • Familiarity with concepts of entropy and its derivatives
  • Basic knowledge of polymer physics and molecular configurations
  • Ability to manipulate equations involving multiple variables
  • Study the implications of the thermodynamic identity in different physical systems
  • Explore the relationship between entropy and molecular configurations in polymers
  • Learn about the statistical mechanics underlying polymer behavior
  • Investigate the effects of temperature on the elasticity of rubber bands
Students and researchers in physics, particularly those focusing on thermodynamics and polymer science, as well as anyone interested in the mechanical properties of materials.
jason177
Polymers, like rubber, are made of very long molecules, usually tangled up in a configuration that has lots of entropy. As a very crude model of a rubber band, consider a chain of N links, each of length l. Imagine that each link has only two possible states, pointing either left or right. The total length L of the rubber band is the net displacement from the beginning of the first ling to the end of the last link.
Using the thermodynamic identity,express the tension force F in terms of a partial derivative of the entropy. From this expression compute the tension in terms of L,T,N, and l.
I'm pretty sure the thermodynamic identity for this system is
dU=TdS+fdl
so then solving for f gets
f=dU/dl - TdS/dl
so I found an equation for dS/dl but I have no idea how to get dU/dl in terms of L,T,N, and l.
Never mind, I got it
14K
