How long will it take for compressed air to reach 29 psi?
To determine how long it takes for compressed air to reach 29 PSI from 49 PSI in a tank, the volume of the tank (1050 gallons or 140.365 cubic feet) is essential for calculations. The flow rate will change as pressure decreases, and the transition from sonic to subsonic flow at 29 PSI is significant for using the orifice flow rate equations. By applying the sonic flow rate equation for both pressures and averaging the flow rates, one can calculate the discharge rate. This rate, combined with the air volume loss at the two pressures, allows for the calculation of the time required for the pressure to drop to 29 PSI. Understanding these principles is crucial for accurately solving the problem.
Matt13
A large tank filled with air is compressed to 49 PSI. A valve is open and air escapes through the hole (d = 0.04 ft) to the atmosphere. How long will it take for the compressed air to reach 29 PSI.
Assume constant temperature.
Not exactly sure how to approach this problem since the flow rate will change as the pressure changes.
I've been trying to use Bernoulli's Equation to get velocity and therefore flowrate, but that is instantaneous velocity so it doesn't help much. If anyone could point me in the right direction that would be much appreciated.
Is this homework?
No it isn't homework, just something I am working on
The volume of the tank is required to calculate the time. What is the volume of the tank?
Volume of tank is 1050 gal or 140.365 cubic ft
Based upon the information given plus the tank volume and an assumed or known air temperature this is the way I would approach solving the problem.
It appears that the 29 psi minimum has been carefully selected because it is just above the point that the orifice flow would transition from sonic flow to subsonic flow for an orifice discharging to atmosphere (14.7 psi) . As a result, the orifice sonic flow rate equation can be used to calculate the discharge rate at both pressures; and, since flow rate vs pressure is linear for sonic orifices and constant temperature is to be assumed, then average of the flow rates at 49 to 29 psi can be used for the entire discharge period.
Once that rate is determined, then what remains is to calculate the volume of air in the tank at the two pressures, again assuming constant temperature, to determine the vessel's air volume loss.
With the air volume loss and the average loss rate (average orifice flow) determined, it is simple to calculate the time required.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
