How long will it take for one cylinder to turn one revolution?
The discussion focuses on calculating the time it takes for a cylinder, initially at rest, to complete one revolution. The user initially attempted to use the formula (Theta)f = (Theta)i + (alpha)(deltaT) but encountered issues due to not having the correct angular acceleration. It was clarified that angular kinematic equations must account for initial conditions, and the user was advised to use the appropriate formulas, considering that initial angular velocity is zero. The conversation emphasizes the importance of correctly applying angular motion equations to solve the problem effectively. Overall, the user seeks guidance on how to proceed with the calculations.
ScienceGeek24
A cylinder is initially at rest, how long will it take for the cylinder to turn one revolution?
(Theta)f=(Theta)i+(alpha)(deltaT)
I know that the distance of the cylinder to turn one revolution is 2Pi over speed. My speed was 0.05 rad/s so i divided 2Pi/0.05 rad/s and it did not give me the right time which is 15.9 sec. Help?
Somehow, this problem, as stated, is rather incomplete.
If the cylinder is initially at rest, what makes it move at all? ... or what describes its subsequent motion?
ok sorry for not being specific.
this question is the second part of the firsst question which is this one.
A solid cylinder is pivoted about a frictionless axle as shown. A rope wrapped around the outer radius of 2 m exerts a downward force of 3N. A rope wrapped around the inner radius of 0.7 m exerts a force of 8 N to the right. The moment of inertia of the cylinder is 8 kg m^2. Find the angular acceleration.
I found the solution to this one by t=+-rFsin(theta) here is the specifics https://www.physicsforums.com/showthread.php?t=583881
However, my solution to the first part of the problem was the sum of all torque forces Sumt=I(alpha)
-Rfsin(theta)+rFsin(theta)=I(alpha) I had my Moment of inertia giving my the problem so all i had to do was to solve for (alpha) which gave me 0.05 rads/s.
The second part of the problem says,
If the cylinder in problem 10 is initially at rest, how long will it take for the cylinder to turn one revolution??
That is the part where i use (Theta)f=(Theta)i+(alpha)(deltaT) and solve for t but it did not give me the right answer.
Assuming that α is angular acceleration, it should have units of rad/s2 , not rad/s .
yes yes sorry for that one.
Angular kinematic equations have direct parallels to their linear counterparts. If θ is angular position, and ##\alpha## is angular acceleration, then your formula above is equivalent, in linear terms, to
## x_f = x_i + at ##
which is not correct. Appropriate linear formulas are:
##v_f = v_i + a t## and ##x_f = x_i + v_i t + (1/2)a t^2##.
and their angular counterparts:
##\omega_f = \omega_i + \alpha t## and ##\theta_f = \theta_i + \omega_i t + (1/2)\alpha t^2##.
hmm which one should I use because I don't have angular velocity I only have angular acceleration. How can i start up with?
You drop any terms that are zero from the equations. For example, if ωi is zero, then ωit will always be zero.
